The absolute best time to protect your Model S is before any damage occurs. Although it is never to late to apply protection solutions to your vehicle our philosophy is prevention rather than repair. The Model S is designed to be driven, and thus will be susceptible to various weathering. Nano coatings are a great way to add peace of mind as well as add significant protection to all the surfaces of the vehicle.
Our client Chris, contacted us upon doing some research on the best solutions for his brand new 85D Model S. After several discussions and extensive research we landed on Modesta Nano Coatings as the best fit for his vehicle. Modesta's line of coatings offers world class protection and up to 10 years of consistent durability. A perfect solution for both new and used Model S owners.
The coating process for new vehicles is oftentimes much less extensive than needed for used vehicles. This is once again due to bare surfaces being much more susceptible to accumulating defects, swirl marks and contaminants.
Our process starts with a thorough decontamination.
Wheels are thoroughly cleaned and decontaminated
The paint surface is then taken through a gentle hand wash process. During this process any loose debris is gently cleaned using lambswool mitts and gentle degreasers.
After the initial decontamination, the vehicle is chemical decontaminated with an industrial fallout remover. This process removes any ferrous contaminants that embed themselves into the paint surfaces. The key to proper bonding of ANY coating is ensuring the paint surface is perfectly clean and defect free.
Here you can see the chemical reaction to the iron contaminants found in the paint surface. This Model S had less than 100 miles on the clock and still showed a good amount of embedded contaminants.
Modesta is unlike other coatings solutions in that it is applied in different layers. The first being an acrylic based coating primer P-01A measured to add up to 10 microns of protection to the paint surface. This product is polished on and left to cure for 12h before the glass membrane is applied.
After this process Modesta BC-04 is applied using a wet application method. Due to the extreme hardness of this coating product, water is used during application and removal in order to aid the application process.
Applicators and microfiber towels used during this process have to be thrown away as they will crystalize and harden due to the purity and hardness of the Modesta coating.
Infrared lamps are then used to bake the coating at 130-50*F for 15 min. This increases both the hardness and durability of the coating by further bonding it to the paint surface.
Then, after curing overnight the vehicle is prepped and ready for delivery after attending to the wheels and various other details.
Please contact me regarding your Model S or any questions you may have. We offer many different protection solutions, Modesta being one of our top Nano Coating options.
Modesta is not for everyone but we can find a solution that best fits your vehicle and your needs.
Tim Coats
Owner, Adonis Detail
Tim Coats
