Just over 24000 miles. Mine's RWD - the D adds a few extra miles of range I think. Very happy with performance over the past 3 years - turns out I got a battery which holds its capacity pretty well and can still charge at 114 kW, albeit for less than a minute if the SOC is down near 10%!@cezdoc Thanks very much Learning all the time! How many miles have you done?
257 Wh/mi is pretty impressive, you're obviously driving very smoothly (and doing a reasonable run in warm, dry weather definitely helps. Using a Supercharger still impresses me (I do a handful of trips each year when I can use the network), don't be alarmed if the car runs noisy fans to keep the battery cool! Sounds like it will be a great day out.We're on a few miles over 30,000 and just over 3 years.
The trip display reckoned we managed 257Wh/ mile on Saturday over 56 miles of M25/M11 and into central London via the City, which was very reassuring, so we beat range estimate.
We're doing a day trip to to France (Dover ferry) on Saturday week, which will be interesting for achievable range.
That could well be our first sample of Supercharging since having the car (collected last Friday).
Are you familiar with the 'urinal' technique at Superchargers?
So I was intrigued enough see what my car was reporting...I just tried plugging my own car into tesla-info and got the following:
Charge level 58
Ideal range 125.88
Battery range 159.45
Est range 131.31
Usable battery 57
I'm going to backtrack about what Battery range means - I think @arg is right in that it's range in Rated miles rather than 100% capacity.The Ideal range figure definitely = range in typical miles.
I'm also intrigued that my usable battery number is less than the charge level but I guess it could be a rounding error. I haven't been out to see what the car says - usually regen is limited even though the weather is getting warmer, so it could be a temperature effect.
Not brand new in December? 2 miles is less than 1%Bad news!
In December, when I purchased my new lifestyle (Model S85D), it fully charged to 257.
I fully charged it 2 weeks ago, to see if there was any change....only 255!
Still works!
Still works!
No it is a May 2016 model.Not brand new in December? 2 miles is less than 1%
Abetterrouteplanner reckons, if we leave home with 100%, we should have 37% charge remaining when we arrive at the Calais Supercharger (not the Eurotunnel one).
The energy consumption target is under 288wH.mile
I haven't yet charged our 70D to 100% - will probabaly do that early tomorrow morning
You can assume that it will get from 90% to 100% (on normal wall charger NOT at Supercharger) at same rate as normal, but allow a full additional hour once at 100% to balance the cells (i.e. the car may take that long to actually stop charging). It will probably take less than 30 minutes ... but it might not.
You won't gain much range in that time, but periodical charging fully to 100% (rather than 99.9% ) will mean the car has better prediction of range (and occasional cell-balancing is A Good Thing)
So start early enough before you leave (or do it overnight and leave the car sitting at 100% for a couple of hours
The 288wH/mile was what the abetterrouteplanner came up with. It did seem rather low
