We have not-far-back historical evidence on TMC that this is not true.
Wondering if this will trigger calls for a new kind of NHTSA "road debris impact" test for EVs w/ large battery packs installed in the underside of the vehicle --- something that gouges the heck out of the pack. I've only put 2000 miles on my car so far and have had several near-misses with road debris that might've done damage to the underside.
I believe you drew the wrong conclusion here.Except for what isn't said. Which is that they refuse to say whether the battery pack was or wasn't involved.
The pack is not designed to have a large metallic object rip through it either.
Given that we have a cause (metallic debris) and a plausible effect (a cascading failure from a pack that was ripped open), I'll take that and run with my speculation in the absence of a statement by Tesla otherwise.
+ 1million....
Geez people, enough trying to be internet heroes
I hope not. Maybe this though...Wondering if this will trigger calls for a new kind of NHTSA "road debris impact" test for EVs
Wondering if this will trigger calls for a new kind of NHTSA "road debris impact" test for all cars regardless of whether they are EV, ICE, or run on glowing green crystals from meteors
There is evidence AGAINST cascade failure. front of car was clearly in flames, and the fire remained contained. Why are you saying this?
Where do you get that anything "ripped through the battery"?? Tesla specifically said: "Subsequently, a fire caused by the substantial damage sustained during the collision was contained to the front of the vehicle thanks to the design and construction of the vehicle and battery pack." Not sure how the fire would have been contained if the battery pack had been ripped open? I'll give you that they didn't specifically say the battery wasn't breached but they also didn't specifically say the car hit a piece of space debris either.
Thanks for noting that you are speculating, but again if the battery pack was ripped open there would have been much more evidence....there are 8,000 batteries in there. You'd probably have seen plenty of them rolling around on the road.
You're usually pretty level headed. This response was not such. IMO.That said, if this was not a battery fire, then the Tesla statement was PR malpractice. They must know that a battery fire is the primary concern, and if this was not a battery fire they should have specifically denied it.
What is your other plausible source? The 12v battery is less vulnerable to this type of damage than the main pack.
A random gas can is even more isolated, and they aren't easy to break in any case. I suppose it could be thrown against the front of the frunk and blow the lid off, which would spray the interior of the frunk. Where is your evidence that there was an impact hard enough to do that? The car rolled onto a transition and stopped, it didn't get stopped by an impact. And even if it did, you then need an ignition source.
In contrast, a piece of every day metallic debris, like that which rips open oil pans and gas tanks every day, could readily rip through the bottom of the battery, not stop the car, and cause a short that would cascade though the pack.
And again, Tesla did not deny a battery fire. Why in the world would an EV company, which faces intense scrutiny over the possibility of a battery fire, not immediately deny that this fire came from the pack?
I am no fire expert. But the fire really does look like it was caused by something that was housed inside the frunk. I just don't see how the sides could be engulfed like that as well as the top and inner section. It looks like a canister of gas that exploded upon collision.
Even if its not, I suppose its a good warning not to leave gas in the front.
I don't think it was a cascading failure, but if a large metallic object ripped through the front part of the pack, that could cause a fire. The fact that it was contained to the front could say that Tesla avoided a cascading failure but at the same time, it was a battery pack fire at first which ignited the frunk.
I'm not saying your prom picture is a good one. Just because I'm not saying (right now) doesn't mean I'm refusing to say it (ever).
Because they don't have data to support that assertion, yet.And again, Tesla did not deny a battery fire. Why in the world would an EV company, which faces intense scrutiny over the possibility of a battery fire, not immediately deny that this fire came from the pack?
CO I see you have used the term 'cascading' a number of times. A pack catching fire from debris impact is one thing, a pack catching fire in one place and that cascading through the entire pack is something else, and would likely cause more concern than the former case. You either do not differentiate between the two, or leap to the conclusion that it is the latter and not the former, and I think that's what folks here are objecting to.
