To reiterate what others have said, balancing does affect actual total range, not just displayed range. If one group of cells is at 60% SOC and the other at 50% SOC you only have the range available from the 50% SOC cells since any further discharge beyond that would take them below zero and send them into reversal, which of course the car will not allow. Your range is always limited by the lowest SOC bank of cells.
3. There is some pack balancing all the time, but the pack can't really be balanced unless it's over 90%. This is just a function of the difficulty of measuring the SOC. It's far easier to do so when the pack is completely full or almost so. Doing a few range charges while on trips (two or three times a year) should keep the pack in balance without undue degradation.
I still remain confused about this. I'll try to put my confusion into words.
Assumptions:
1. There are 5 cells.
2. When new, each cell is manufactured to store at least 10 kWh.
3. User sets charge slider to 60%.
Case A
If all the cells are brand new and not defective, then at charge completion the 5 cells each have at least 6 kWh stored. Total of 30 kWh, or 60% of original capacity.
Case B
Degradation results in the following capacities: { 9, 8, 7, 6, 5 } kWh.
Case B1 - Each cell is charged to the specified_limit
At charge completion, the cells have { 5.4, 4.8, 4.2, 3.6, 3.0 } kWh stored. Total of 21 kWh, or 42% of original capacity.
Case B2 - Weak cells are charged to cell_capacity, stronger cells hold some extra in a proportional fashion
10 * 0.6 = 6.0
Thus { a, b, c, 6, 5 }. Need to solve for a, b, and c.
(6+5) kWh = 11 kWh
60% * 10 kWh * 5 = 30 kWh
(30 - 11) kWh = 19 kWh
a = 9/(9+8+7) * 19 kWh = 7.125 kWh
b = 8/(9+8+7) * 19 kWh = 6.333 kWh
c = 7/(9+8+7) * 19 kWh = 5.542 kWh
At charge completion, the cells have { 7.125, 6.333, 5.542, 6, 5 }. Total of 30 kWh, or 60% of original capacity.
Notice the SOC relative to current capacity for the cells: { 79.2%, 79.2%, 79.2%, 100%, 100% }. I'm presuming this leads to accelerated degradation, especially for the 4th and 5th cell.
This leads me to believe B1 is preferred to B2. So let's run with that...
Revisiting B1:
The user asked for 60% but only got 42%. Seems like a rebalance might be in order. Assuming the user left the vehicle plugged in (and some additional set of criteria perhaps), why wouldn't the BMS want to rebalance these SOCs to ...
{ 4.2, 4.2, 4.2, 4.2, 4.2 }
... and the capacities to ...
{ 7, 7, 7, 7, 7 }
Is there some downside to doing this after every charge completion -- regardless of the slider setting?
