Model S bluetooth issues
Discussion in 'Model S: User Interface' started by dsm363, Oct 3, 2012.
  1. dsm363
    dsm363 Roadster + Sig Model S
    Nevada
    Has anyone else had trouble getting their phone to pair? When it was delivered, it took about 10 minutes to pair my iPhone 4S. It worked until yesterday when it took maybe 15 attempts and was finally able to get it to pair again. I wonder if there is a certain sequence you're supposed to take to get it to recognize the phone (start with Model S then go to iPhone maybe).
  2. AnOutsider
    AnOutsider S532 # XS27
    Do you have a lot of contacts? I know some cars have issues downloading large phone books.
  3. dsm363
    Nevada
    I have a little over 400 contacts so doesn't seem like a lot. It's working again for now.
  4. MikeK
    MikeK R#129, TSLA shareholder
    San Francisco Bay Area
    Yesterday I dropped by the Menlo Park showroom. I sat in the silver-with-black-roof demo car, tapped the Bluetooth logo at the top of the 17" screen, opened the Bluetooth prefs on my iPhone (4S running iOS 6), then tapped the button on the 17" to look for devices. It showed up within a few seconds, I tapped the button to accept, then tapped the button on the phone to confirm the displayed code. Done. I was able to play music and use Siri via the Bluetooth connection.
    OTOH, at the August Get Amped event in Palo Alto, I saw somebody else having no success getting their phone paired. It seemed to be a timing issue -- the dialog appeared on the 17" for a split second, then disappeared. He was never able to tap it in time.
  5. dsm363
    Nevada
    That's the issue I'm having at times. It will say something like use code 576934 to pair and there is a 'pair' button but it will only stay for less than half a second and the next message will say 'make sure your device is in range' or something. I have a feeling things need to be done in a particular order.
  6. cinergi
    cinergi Active Member
    MA
    I had those timing issues pairing my iPhone 5 to the Model S in the Natick showroom. I didn't figure out the correct order but after trying several times, I managed to pair it up.
  7. dadaleus
    dadaleus 4GETOIL P85#S70,FdrX,S85D
    Solana Beach, California, United States
    Sorry... mine has worked flawlessly. I've actually been very impressed with the bluetooth functionality. I'm using an iPhone BTW.
  8. W.Petefish
    W.Petefish Active Member
    #8 W.Petefish, Oct 8, 2012
    Put your phone under the display and try again. Seems as if the bluetooth has a short range/directional antenna.
    EDIT: Bluetooth keyboard does not pair w/ Model S.
  9. Elshout
    Elshout Member
    Novato
    #9 Elshout, Mar 4, 2013
    My iPhone paired almost instantly with the MS, however, it took a dump today and will not pair at all. Don't know if the problem is with the iPhone or the MS.
    Sent an email message to the San Rafael Service Center and Steve Bainbridge, the service manager, gave me a quick fix which worked. Delete the MS from the iPhone, delete the iPhone from the MS and start the process of pairing. Worked like a charm
  10. 100thMonkey
    100thMonkey Member
    Seattle area
    I've found the streaming to be glitchy with either slacker or blue tooth pandora through iphone 5. This could be the signal, maybe it's AT&T or ? on occasion the song gets cut and my phone gets dropped and then I can't get it to recognize the phone again till I reenter the car. so far I am a bit disappointed with this, I've never had this kind of an issue with my past blue tooth enabled cars. To be fair, I have not taken it in or even let them know it's happening. I figure once I get 3-5K miles on it, i'll be willing to let it go for a few days to let them sure up a few minor things.
  11. Larry Chanin
    Larry Chanin President, Florida Tesla Enthusiasts
    Sarasota, Florida
    On two occasions I found that my Android phone would not be recognized by Bluetooth. On those occasions Internet connectivity wouldn't work either. Rebooting the main display corrected the problems in both cases.
    Larry
  12. 100thMonkey
    100thMonkey Member
    Seattle area
    how does one reboot the main display?
  13. dsm363
    Nevada
    Hold down both scroll wheels (push them in) for 10 seconds or so.
  14. digitaltim
    digitaltim Sig737 VIN628
    MD, USA
    Alternately, I just remove and re-add the Bluetooth device which has worked the one or two times in 3 months where my iPhone 5 would not pair.
  15. Larry Chanin
    Sarasota, Florida
    On the two occasions that I rebooted the display, Bluetooth would not initialize therefore it was not possible to pair the phone with the Model S. After the reboot everything worked fine.
    Larry
  16. nrcooled
    nrcooled P#8946 VIN 03225
    NoVA
    I am in the habit of turning off my WiFi and Bluetooth on my Galaxy SIII to save battery during the day at work. I have found that, for my phone, the WiFi MUST BE ON to connect via bluetooth to the car. I have no idea why this is and I have searched to try to figure out why. The other thing that I have noticed is that the connection is much more consistent if I have bluetooth on when the car wakes (when entering the car). If I turn it on in the car I have to do a "little dance" to get the connection up.
    Other than that the car connects everytime to my previous iPhone 4S and now GSIII.
  17. sp4rk
    sp4rk Banned
    Schaumburg, IL
    I too had this problem ... however, after having reset the main display to no avail, I re-seated the battery in my phone and all worked fine.
    YMMY.
  18. PeterK
    PeterK Model X & 3 Owner
    Cambridge, MA
    Not exactly a bluetooth issue per se. I have successfully paired an iPhone 5 and Blackberry but I get the following strange behavior. The car appears appropriately set to be on Eastern time (perhaps identified through GPS location?), but it assumes the phones are on Pacific time and adds 3 hours to the times in the call histories. So this morning at 9:30 I looked at call history, and a call I made at 8:15 was showing as taking place in the future, at 11:15. Odd.
    Anyone else have this issue? Ideas on how to address? Both phones know they are in Eastern time zone.
  19. 100thMonkey
    100thMonkey Member
    Seattle area
    FYI, I did the reboot and now the car won't recognize my phone at all and no remedy. TM says I need some special fix requiring a quick visit to the local service center, heading down soon, will report back after.
  20. Vger
    Vger Active Member
    Salt Spring Island, BC, Canada
    I have heard that there are Bluetooth improvements coming in the pending 4.3 firmware release.
