Model S calliper bolt torque
skrenes
118
122
Calgary, Canada
Hi everyone. Does anyone happen to know the official torque spec for the calliper bolts and perhaps the hex screw that holds the brake rotor on the hub? I assume it's the same for all Model S', but in case it isn't, I have a 2013 P85+.
I want to remove the rotors to spray paint them with high temperature calliper paint, after removing all the rust on the hub area. I was going to also bake them in a makeshift oven.
appleguru
959
1,707
MA, US
120Nm for caliper to knuckle bolts.
17Nm for rotor to hub screw
42Nm brake hose to caliper bolt + sealing washer (discard and replace)
8Nm brake dust shield to knuckle
Appears to be the same for all model s (front and rear)
