Random anecdata point from last night, please check my work, which is prone to severe errors:
Outside air temp was low 40s / high 30s F and the garage was left open for a while (oops!)
The outside air temperature on the display after coming home from a drive showed 41F, which seemed colder than it actually felt like inside the garage, but it was definitely raw and chilly and not a comfortable space to work. I dont have a thermometer to check, but wearing a hoodie it was damned cold. Going to guess maybe low 50s inside the garage?
I closed the garage doors and opened the front and rear doors and sunroof on the S 100D. I turned heat on HI (max heat, no AC, max fan speed, recirc, all vents open) and went inside.
40 minutes later, I came out to do my painting. Interestingly the dash still showed 41F, but there was no way that was accurate as I could now easily work comfortably in jeans and a T-shirt and am guessing the temp inside the garage was probably in the mid 60s? (For reference the space is about 30’ x 40’ with 8’ ceiling.)
TeslaFi shows the following:
Starting Range: 248.72 miles
Ending Range: 234.46
Time: 40 minutes
Range Loss: 14.26
kWh Loss: 3.87
Somebody math-y-er than me should confirm, but it seems like the heat on full blast uses(d) about 5.8 kWh?
Also seems like your average “room” space heater is about 1.5kW and puts out around 5,100 BTU, so is it fair to say the Tesla puts out around 20,000 BTU on paper? (Though almost certainly much less...)
A random Google search for “how much BTU to heat a room” seemed to indicate a well insulated space with no windows, concrete floor, and heated area above (living space) would require about 16,000 BTU, and I believe (while quite inefficient!) the car would’ve been capable of getting the space into the low 70s and maintained that temperature without being on full blast.
So all this is to say that my thoroughly unscientific, practically failed math my whole life experiment shows my Model S puts out anywhere from 12,000 - 18,000 BTU at 5.8kWh. YMMV and all that.
(For those considering camping IN the car with doors and windows closed (even on a cold night) note that the car would be roasting on the interior in short order, so you shouldn’t expect to burn anything close to what I burned when using my car as a bastardized space heater.)
