Model S/Chevy Volt issue: Help Needed
Discussion in 'Model S' started by Mkent, Aug 18, 2012.
Tags:
  1. Mkent
    Mkent Member
    Greenville, SC
    While I am excited and awaiting my Model S delivery (sometime in 2013), my teenage son is going to buy a Chevy Volt. Problem: What to do about charging? I really do not want to upfit the garage with two chargers. Is there a solution here? I was planing on installing the Tesla wall charging unit. I am sure it is not compatible with the Volt or is it. My Chevy dealer said no. He was a little miffed I was buying a Model S too! Any thoughts or advice?
    Thanks
    Mark
  2. NigelM
    NigelM Recovering Member
    Northern Virginia
    Check out this thread: Preparing-for-your-Model-S
    That should help you, particularly the most recent posts which have been discussing multiple cars in one garage.
  3. RichSh
    RichSh Member
    Des Moines, IA
    The Volt can charge overnight while drawing 12amps of 120v using their provided charger. The Tesla would require something more like 30-40 amps of 240v to charge over night using their provided charger. In my case, we charge my wife's Volt off of 120v using a 20amp circuit (without much else on it--just 1amp draw from some landscaping lights, will need to keep my xmas display under control) and a 15amp outlet. We'll be running a 50amp 240v line from a new sub-panel and putting a modern dryer outlet in the garage to charge the Tesla at 40 amps. No need to actually buy any chargers, as they are provided with the cars.
  4. Mkent
    Mkent Member
    Greenville, SC
    . RichSh great solution! Thanks for the help!
    Mark
  5. J in MN
    J in MN S60 P12635
    Minnesota
    People often forget, but the amount of charging you need to do is determined by how much you DRIVE, not by the size of the battery in the car. If you are determined to have only one EVSE in the garage, the better choice would be a J1772 unit capable of 40 A.
  6. Trnsl8r
    Trnsl8r S85 2012-2018, X90 since 2016, 3 since 2018
    San Jose, CA
    I was always planning of forgoing Tesla's proprietary unit and instead having one or two 14-50 outlets installed, for compatibility with other cars. (Either guests' or unknown future cars.) Thoughts?
  7. Sparrow
    Sparrow S105/ Roadster 189
    Marietta, GA
    Trnsl8r, my first thought would be, that other than Tesla, the other EVs I have seen don't come with 240 volt EVSEs that can plug into 14-50 outlets. The buyers of these other EVs can possibly convert their 120 volt EVSEs, that came with their cars, to 240 volt or they can buy seprate EVSEs (although not from their dealer), but I wonder how many EV drivers will go thru that hassle and expense. So what I am saying is that unless you have a spare 240 volt J1772 EVSE that you can plug into a 14-50 outlet, you probably won't be helping your friends with charging unless they own a Tesla.
  8. Jrhodesmd
    Jrhodesmd S Sig #371, X Prod #1143
    Austin, TX
    I was wondering the same. My "If everything goes perfectly" plan had been to just install the HPWC and use it with both my wife's possible Model X and my Model S. However, my rep at Tesla warned me not to bank on the charge port for the X being the same as the S. Although battery technology changes (somewhat slowly) over time, I wonder that given both cars are sharing the same platform why they would even think about making ANOTHER proprietary charging port? Anyways, she recommended that everyone put in a 14-50 plug, even if you are doing a EVSE, in case the ports/technology change. Not a bad idea IMO.
  9. dmunjal
    dmunjal Active Member
    Does it have to be a 14-50? I only have a 14-30 (dryer outlet) that I use to charge my Leaf via EVSE and J1772. Couldn't I also use the same for the Model S J1772? Or should I upgrade it to a 14-50? Would that even work with my Leaf and the J1772?
  10. Sparrow
    Marietta, GA
    The Roadster had adapters for the various 240 outlets around, so I would assume at some point Tesla would make an adapter for the S to utilize a 14-30 outlet, but from what I have heard so far the car comes with a 14-50, I just don't know when the other adapters might be available. Of course if you have a J1772 EVSE plugged into a 14-30 already, the S does come with an adapter for J1772 so you could charge the S with that J1772 EVSE anyways with no modifications necessary.
  11. brianman
    brianman Burrito Founder
    That's a great way to lose a sale. Foolish dealer.
  12. FlasherZ
    That's what I'm doing. I already have a 14-50 welding outlet in one of the garages, and on the subpanel on which my HPWC will be connected I will have another 14-50.
  13. Trnsl8r
    San Jose, CA
    Newbie question (and too lazy to look it up) but is there any forward/backwards compatibility between 14-30 and 14-50? I.e., could one have use of another?
  14. Bifff67
    Bifff67 Member
    Northern Virginia
    The pins are different. You need the right adapter to match the plug. The 14-30 gives you a little less than 30 amps and the 50 a little less than 50 amps.
  15. MikeK
    MikeK R#129, TSLA shareholder
    San Francisco Bay Area
    It would be **INSANE** for Tesla to change charging port when they're going to spend a bunch of money building the Supercharger network. I would be stunned.
  16. PhatCat
    PhatCat Kisco Kid
    Mt Kisco, NY
    Customer: You have a problem with my son getting a Volt and my getting a Tesla Model S?
    Volt Salesperson: Yes, I do.
    Customer: No problem. I'll get my son an S.
  17. brianman
    @PhatCat - Exactly.
  18. Dan5
    Dan5 Member
    Delran, NJ
    I had was having the same issue when my gf was considering a Volt, we decided that the 110 outlet would be hers and the 220 would be mine, had to move a fridge to the basement to free up and outlet, but it was fine.
    Also when we were looking at the Volt, the salesman kept on mentioning the "range anxiety" and that I should get a Volt instead of a Model S....I hate that
  19. Duckjybe
    Duckjybe Member
    Ontario, Canada
    I have a Volt (which I love by the way) and the Model S is reserved. I put in an 80 amp subpanel myself in my garage and right now have a 6-30 outlet for my Volts SPX power Xpress EVSE ( charges in 4 hours). I will put in 14-50 for the S when the time comes. Hopeful this will work out!
  20. strider
    strider Active Member
    NE Oklahoma
    You can absolutely keep your 14-30. I have a 10-30 (same amperage as yours but IIRC doesn't have a separate ground) that I use for my Roadster and we're going to add another for my wife's Model S. We don't need to charge quickly as my commute is 60 miles and hers is 25 so plenty of time to charge by morning.
    From here: Charging Model S | Tesla Motors
    Model S comes a 5-15 (standard 110V outlet) and one of the following 220V adapters (you choose when you take delivery):
    NEMA 14-50
    NEMA 6-50
    NEMA 10-30
    NEMA 14-30
    The car will charge at 80% of the outlet rating although you can decrease it even more. So with your 14-30 it will charge at 24A which is ~16 hours for a full 85kWh charge. If you step up to a 14-50 you will charge at 40A and decrease a dead to full charge to 9.5 hours. If you do step up to a 14-50 you could probably switch your Leaf EVSE to 14-50 as well but again, if you don't need the charge speed just leave it as is.
