Model S comes with 4 camera mounts / tripod mounts on the roof??
Discussion in 'Model S: Interior & Exterior' started by danwat1234, Jan 1, 2013.
  1. danwat1234
    danwat1234 Member
    So I took a looksie at the Model S charging up at the Washington Square Mall in Oregon yesterday. Nice looking car, lots of cargo space, lots of leg room, the battery doesn't intrude into the cabin.
    But then I started looking closely at the body and I noticed a little door on each corner of the roof. I opened each one up and I found what looks like a camers mount, one for each corner of the car!
    Must be because it's a show car. I LOLed though.
    Pics.
  2. RLA12194
    RLA12194 Member
    Houston, Texas
    For an optional roof rack...details still forthcoming. Only for the pano roof option, AFAIK.
  3. danwat1234
    danwat1234 Member
    For a roof rack? Those 4 doors would be open all the time then, rust issues for the metal in between the outer roof and inner roof? Also I don't think there are any gaskets for those doors.
    Those mounts look very weak, the base looks like it is either plastic or maybe magnesium alloy with the threads being metal.
    - - - Updated - - -
    I think metal threds, could be plastic.
    BTW, how do you edit posts on this forum? Maybe I'm a newb and I have to post more first.
    - - - Updated - - -
    Oh... that's how
  4. goaliemanshark
    Actually good idea. Maybe I should mount a GoPro on there
  5. jerry33
    Texas
    The aluminium shouldn't rust so a gasket shouldn't be required.
  6. strider
    strider Active Member
    NE Oklahoma
    They are the same attachment points that Mercedes uses on their cars so if there was a problem w/ them they'd know by now. Also, the car is aluminum so little chance of rusting :)
  7. aronth5
    aronth5 Long Time Follower
    Boston Suburb
    It has been posted before that you need the pano roof for the optional roof rack.
    I am sure there is a good reason for this but can someone explain why?
  8. jomo25
    jomo25 Active Member
    Scottsdale, AZ
    Not really a good reason but here's my understanding. The S was always envisioned to only be available with a pano roof. So, a lot of engineering and design went into it. The non-pano roof option was an afterthought, but decided to be offered late in the process, probably due to customer feedback. Thus it was designed quickly and simply -- without the rack points. Non-pano roof might be available with rack points in the future, like on S 1.5 or something like that.
  9. ZBB
    ZBB Emperor
    Scottsdale
    Those are pretty standard mounting points -- while Tesla is likely using the Daimler / Mercedes part, they are also found on Audi, BMW, etc. Thule and Yakima both make roof racks that mount on them... Here's the part that goes into that mount (and I'm guessing that the little door can be detached and put in storage while the rack is on the car).
