I think you may be screwed and need to use a laptop plus local wireless (bring your router to the car rather than the car to the router) for the transfers.Will this work in a Condo? My living unit is far from my under ground parking spot. Not sure how the S will get on my home network….help!!
Also I assume you could purchase a data plan and push stuff over the 3G/4G connection. Most of those have a 5GB/month or so cap on them now but that's a fair amount of data. You could do the initial upload with a couple trips on a thumb drive.I think you may be screwed and need to use a laptop plus local wireless (bring your router to the car rather than the car to the router) for the transfers.
I plan to hook my car up to work wireless and home wireless.
Thanks for the suggestions, I'll check them out.
Take delivery at the nearest Tesla Store or at home. I think that delivery at the Tesla Store w/ a full charge would be -really- good press.
Even if the location that you can run the Ethernet cable doesn't have power, say the eaves of your house or something, you can also buy a wi-fi router with POE (Power over Ethernet). So all you have going to the router is the Ethernet cable.
You should be able to get someone to set up something that works for around $500-$600 at most.
Use DD-WRT to increase your output power. (FYI DD-WRT is a free wireless router firmware.)
Will it work with any router?? I use an airport extreme router
If you choose to have the car delivered to your house, what is the process? Do they just drop the car off? Or will there be some type of process? When you pick up at a location they go over everything with you and the car is detailed.
