Hello.
Has anyone any idea what GTW_w025 is?
Got this code first time in July when tesla Changed the main battery and 12v battery of my Model S70D. Then they fixed this code by change of new fuse box. Car worked well.
Now its winter and quite cold here in Finland. Code appears again usually after 5min of driving. Air suspension stops working and red suspension warning appears. After car is parked about 15min code goes away and suspension works fine. If temperature is very low, like -20 degrees celsius, car won't reset the code and suspension warning stays on. Again 15min on warm garage fix everything.
I don't think this is suspension problem since it works fine when code is off. Could it be 12 volt issue? Voltage drops in cold and under load when driving. Maybe new 12v battery is not fine or DC-DC charger not working as it should? Now I will start measuring voltage of 12v battery.
Any ideas?
Thank you.
-V
Any ideas?
Thank you.
-V
