MODEL S EXPERIMENT: Plug in a USB wifi adapter in the usb socket,?
Discussion in 'Model S: User Interface' started by Babylonfive, Nov 26, 2012.
  1. Babylonfive
    Babylonfive Power12
    Cedar Park (Austin), Texas
    This might be an interesting experiment - plug in a USB wifi adapter, then reset the dash computer?
    You could compare a network speed web site response before and after? I ask because some linuxes come with all the autodetecting drivers built-in, and it might just work off the rack... you'd probably not get a a pop-up allowing you to specify the access point or add a password... hmmmm...
    Thoughts?
  2. cinergi
    cinergi Active Member
    MA
    I tried just for giggles. No dice with my iPhone 5. (I confirmed I can share 'net over USB with my Windows 7 machine tied to it; the phone shows there's someone using hotspot in that case. It didn't show that with the Model S)
  3. FlasherZ
    It would probably be better to try a wired ethernet adapter which doesn't require SSID setup, etc., to see if the networking stack activates. A simple Realtek-based wired USB adapter and the appropriate sniffer would show you if anything was working. :)
  4. cinergi
    MA
    Oh, A USB cell-modem thingy? I was just doing hotspot-via-USB which requires no client setup.
  5. FlasherZ
    No, a wired ethernet adapter, connected to your home network. Wireless USB adapters require SSID to be set, etc. It'd be interesting to see if the Tesla picked up a wired USB ethernet adapter, then attempted to do DHCP on it.
  6. Babylonfive
    Babylonfive Power12
    That's a great idea Z. I hadn't gone that far, wondering. Cinergi, you could just plug in a likely USB wired ethernet adapter to see if it comes up! It'd need a long ethernet cord to your router, to be sure.
    I wonder if a knowledgeable Linux person would know the likely adapter manufacturer that's supported in recent builds? Then we could buy that adapter for the test?... I'm sure I could actually find someone closer to test it on...
    David
    - - - Updated - - -
    No, it's a USB wifi adapter I was suggesting. Like this. But see my comments later that it probably won't start up with all the proper info boxes for access point selection and password...
  7. FlasherZ
    Well, I got out my trusty Realtek USB wired ethernet dongle and watched the network... it doesn't do DHCP. That's not to say the model S doesn't load the driver or have a default IP -- I didn't do any of the work to see (pinging broadcast, etc.) But a quick 2-minute demonstration ruled out easy configuration of a network device attached to USB.
  8. cinergi
    MA
    Their kernel is likely bare-bones with either just a couple available modules or perhaps all statically-linked. We can obviously try but we'll be guessing at which modules are available to the kernel (or compiled in).
    Brainfart. Right. Duh.
    It's been a while since I've used Linux as a desktop ... I wonder what chipset (which driver) is the most common (and/or used in the most devices)? But even with a wide-open wifi, you'd still have to instruct the OS to attach to it and tell it it's DHCP, etc. There'll be no network profiles for the device even if the device does install & load the driver.
  9. Babylonfive
    Babylonfive Power12
    OK. I give up....:wink:
  10. Babylonfive
    Babylonfive Power12
    THanks to Cinergi and Flasher for having a look. I appreciate it... it'll probably be 2 months before I get a chance to investigate with the Silver Beauty.
  11. JerryNycom
    JerryNycom Member
    New York
    When does Wifi come to the Model S and when it does do we have to use our phones as hotspots or can we go the USB dedicted route? 4G in NY is really fast and would only use the 3G in the car for backup.
  12. jerry33
    Texas
    WiFi is not yet implemented. The hardware is there but the software hasn't been finished yet. It will be pushed in a update when it's ready.
