Model S Firmware 5.x Bug Tracker
Discussion in 'Wiki' started by NigelM, Aug 16, 2013.
Tags:
Thread Status:
The first post in this thread is a WikiPost, and can be edited by anyone with the appropriate permissions.
  1. NigelM
    NigelM Recovering Member
    Northern Virginia
    The goal of this Wiki is to collect the bugs in firmware versions 5.x.
    Discussion on this FW version is here: Firmware 5.0 (Superseded by v5.6, see note below*)
    First iteration of the firmware is (1.35.96)
    *Note that v5.0 was issued to a limited number of cars and then halted as bugs were addressed. This was then replaced by v5.6 which is on full roll-out as of early November 2013.
    Discussion on Firmware v5.6 can be found here.
    For each bug we should also note whether it has been reported and whether there is a response from Tesla.
    Build 1.35.76 (Version 5.5 in pre-production European spec car)
    no data known
    Versions of 5.0
    Build 1.35.96
    BUGS (i.e., the software does not do what it is supposed to do)
    Display:
    Seat heater UI doesn't show up in display
    solve by: reboot center screen
    BROKEN AS DESIGNED (i.e., the software works as designed, but the design appears broken - there is a gray area between this and a feature request... feature requests are collected in the thread Model S Software/Firmware wishlist )
    Maps:
    Street names are upside-down when maps are rotated (and driving South)
    reproduce by: switch map into "car orientation" mode and drive South
    reported: known to Tesla
    response from Tesla: "this is a documented 'feature'"
    Build 1.35.102​ (no changes reported compared to .96)
    GPS accuracy issues reported on new deliveries
    Reported issues on a German Model S:
    Homelink: Because of SleepMode, it forgets the learned codes. Problem is known to tesla.
    DAB (Digital Adio Broadcast) digital radio: It is loosing the audio signal, poor reception. Despite it has still reception, it shows text and pictures of the current songs, the radio keeps mute. Problem is known to tesla.
    Data connections breaks from time to time. After reboot of the panel it starts working again. I used tethering with my iphone to work around.
    Build 1.35.104
    Build 1.35.106​ (no changes reported compared to .96)
    Build 1.35.107 (no changes reported compared to .96)
    For each of the 5.0 builds there appears to be at least one Model S that shows the GPS "confusion" issue (or is it a compass issue?) where the car location is off or the map suddenly starts spinning around.
    Given the small sample size it is unclear what specific fixes the later versions contain.
    Versions of 5.6
    Build 1.45.32
    This version adds an option to turn of sleep in order to get faster car startup
    This version fixes the "street names are upside down driving South" bug
    No improvement at all regarding bugs noted above, but charging is limited to 3x13A at each charger = Total of 26A on both, down of 32A or 20% less charging power.
    Build 1.45.45
    This version has shown up as OTA update for cars previously on 4.5
    Differences to 1.45.32 are unknown at this point.
    P85+ changed to a P85 on the dash screen and the info screen on the center console (This has been challenged as incorrect - apparently the '+' never showed up before, either)
    Some UI screens reset to default during sleep mode
    Versions of 5.8
    Build 1.49.22
    v5.8 appears to remove the automated lowering of the air suspension at highway speed -- apparently this is intentional as a response to the two fires caused by road debris; see below under 'Broken As Designed'.
    Build 1.49.24
    Differences from 1.49.22 are unknown at this point.
    Common for all 5.8 builds:
    Both .24 and .22 display a noticeably different regen behavior in standard regen mode for some but not all people who received the upgrade. Rebooting both screens appears to bring back the old (stronger) regen behavior.
    There is at least one report that mentioned that the steering went from sport to soft for them. This also was fixed with a reboot.
    BROKEN AS DESIGNED
    Both 1.49.22 and 1.49.24 disable the automated lowering of air-suspension equipped cars to the 'low' setting at highway speeds. They also prevent manual setting to 'low' at highway speeds. There are reports from a number of drivers who (I assume on closed race tracks or the Autobahn in Germany) have confirmed that the car does lower to the 'low' setting at about 100mph and then stays low until the speed drops below about 60mph.
  2. Discoducky
    Discoducky Active Member
    Seattle
    So cool! Thanks for setting up this wiki Nigel!
  3. apacheguy
    apacheguy S Sig #255
    So Cal
    Sure would like to get my hands on 5.0. There don't seem to be many bugs at all according to this wiki. Aside from a long connection time through the mobile app, 5.0 seems pretty solid.
  4. 4SUPER9
    4SUPER9 Active Member
    How 'bout: slow to wake from iPhone app. Probably a feature to compensate for sleep mode.
  5. roundy
    roundy New Member
    United States
    #5 roundy, Sep 26, 2013
  6. brianman
    brianman Burrito Founder
    @roundy - Please send a link to your video to [email protected] so that (hopefully) they can have this investigated, as your video likely has enough specific data for them to dive in deep. Thanks!
  7. Lloyd
    Lloyd Well-Known Member
    San Luis Obispo, CA
    Were you in areas where the President or any part of his cabinet was traveling? The government will degrade the signal in localized areas as they deem necessary. Notices to Airmen will list the predicted degradation.
  8. brianman
    Conspiracy theory begins: "Gov't hacked my GPS" ;)
    Good point, though, Lloyd.
  9. apacheguy
    So Cal
    Never heard this one before. I don't see how they could do that from the satellite level without affecting all users receiving signal from it. Unless they generate some ground based interference, which seems like it could do more harm than good.
  10. ajhughes
    ajhughes New Member
    New Jersey
    I have the same issue with my P85+ which I took delivery of last week. Tesla service said they were aware of the issue and working on a fix.
  11. dirkhh
    dirkhh Middle-aged Member
    Portland, OR, USA
    What's the firmware build number? It would be nice to get more details :)
  12. Cheerose
    Cheerose Member
    Las Vegas, NV
    Got the same GPS issue... along with the poor dead reckoning & the donuts on the map. Supposedly the service center is ordering a part and will call me when it's in to install/replace.
  13. dirkhh
    Portland, OR, USA
    Same question: would you please share the exact build # with us? You can get this when you tap on the Tesla symbol.
  14. Eberhard
    Eberhard #421 Model S #S32
    Germany
    I got my Model S on 22nd august at the delivery event in Tilburg.
    From the very beginning i had this bugs:
    On sunday I installed 5.6
    No improvement at all but found that charging is limited to 3x13A at each charger = Total of 26A on both, down of 32A or 20% less charging power.
    Was very disappointed and upset, mainly because of lack of communication.
  15. tiditisj
    tiditisj New Member
    Belgium
    I Have the same 13A limit since I upgraded to 5.6.
    Tesla says this was done on purpose to solve charging issues (I didn't solve mine...).
    It will be set back to the original 16A in an update in November.
  16. NigelM
    Northern Virginia
    Added v5.8. Version identifier needed.
  17. NigelM
    Northern Virginia
    Edit: got it. 1.49.22
  18. SUN-day Driver
    There was a report that on 5.6 (1.45.45 I tink) TuneIn stations that are weak but were usable before no longer come in over 3G. It's in the 5.6 thread somewhere but didn't make it to the Wiki.
    I'm actually considering not updating from 4.5 to 5.6 because my favorite station is a weak TuneIn station and I don't want to lose access to it.
Thread Status:
