Anyone interested in upgrading to folding mirrors? I have performed this upgrade to my own 2013 MS and it works perfectly. Takes about a day to install. Once complete it works the same as a car originally equipped with factory folding mirrors. Mirrors fold when handles retract or you push the fold button on the drivers door. Mirrors unfold when you open a door or press the button again.
Parts required are:
Both power folding mirrors (any color)
Both front door wiring harnesses (from door with folding mirrors)
Driver side control panel (so you have the folding mirror switch)
You can source the parts or I can. Can be any color as the painted part is interchangeable between mirrors. Work to be performed at my location in Surprise Arizona.
Besides needing to remove the interior front door trim, part of the dash must be disassembled to access and log into the center console for the software config change.
I can also add ambient lighting or "flip the switch" so your existing wiring will work, allowing you to install your own ambient lighting. Option will be available on the touch screen.
Parts required are:
