I have been having issues with my HPWC (I am on my second, the first contracted an intermittent split in the cable about 18inches from the outlet of the HPWC.
The problem was this,
All's well until I pug in, I get the reassuring clunk but then the lights near the charger port go dark blue and not green and the HPWC shows a single solid red. As soon as I disconnect, the HPWC goes back to single solid green. No amount of resets (of any flavour) and advice from Tesla support would cure this (stand on one leg, face east etc). My standard 3 pin charging cable was working fine so probably not the car and probably the HPWC.
Anyway the final advice from Tesla, that cured the issue, was to partially dismantle the HPWC and to move DIP switch 2 from upper to lower. Now I'm pretty sure the installation instructions say this setting is 'not available' and it categorically states that DIP2 must be set to upper at all times.
My question is, what does DIP 2 do (I have scanned forums etc and the consensus was 'nothing')?
Is this just snake oil from Tesla support?
Anyone else have similar issues?
It may be a coincidence but during the fault period, the unlock button for the charge port, on the HPWC, stopped working wheres the normal 3pin-cable unlock button worked fine. Some sort of comms issue??
Thanks in advance folks
