Arcam
Living the Tesla Nightmare
That's interesting, so you get 2 taps on your incomming supply?
sorry, I did mean 120v, I was thinking of a shaver socket
It's called "split phase".That's interesting, so you get 2 taps on your incomming supply?
Do you guys in the US have a choice between 110v and 220v?
Obviouly 110v cables have to be twice at thick to carry the same power which makes them a pain to route, in the UK we have 230v (nominal) so for 7.2Kw we just need 32a which runs on 6mm cable just fine.
Yes, Nosecone Tesla's could do 80amp charging at 240v, which required a 100amp circuit, but that is hardwired into the circuit.I can see the lower voltage argument to a point with very old consumer/fuse boards, but what at whatever load for the same wattage the cables on 120v need to be twice as thick. I understand that it is too ingrained now in the US to change over, can your 220v supply still give 100A?
Sorry, this is digressing from the original post, happy to leave it here.
You're still stuck on that "same wattage" thing. What kind of wattage are you talking about? Like I said, any of the regular household products are low power, so 14 gauge or 12 gauge wire can be used for that stuff, because they never go over about 15-20 amps. That's still pretty thin wire. Any loads that DO require higher power, where the wiring thickness might be a problem with 120V, just DON'T use 120V.but what at whatever load for the same wattage the cables on 120v need to be twice as thick.
It was just an observation on the AWG of the cables required to supply the same piece of equipment. In the UK we would typically use 14 gauge (1.5mm) for lighting circuits and 10 gauge (2.5mm) for 32amp ring mains (effectively 5mm cable - 2 * 2.5mm) all or course at 230v.
I am presuming that either "live" combined with the neutral could supply the 120v rail in a property, would a typical property balance the load between the 120v rails with say the ground floor on one and the upper floor on the other?
It was a real eye opener when we moved from the UK to Canada - the household wiring is one of the few things I miss from the old country.....
We usually have a lot of 120v circuits in the house for various things, so yes, they are balanced across the two “hot” legs as you describe. If you look at a USA circuit breaker panel each alternating spot is on the opposeite phase leg. So if you install them in order you will get aboit half on each hot.
If you install a double wide breaker it spans two hots and gives you 240v.
So on your “ring” circuits, do you attach both ends back to the panel? How about for your lighting circuits?
Well, um, possibly...in theory...maybe. But that's just not something that is done. No one would ever use 120V for a 12kW power circuit. They don't make 120V breakers that big. That's what I keep mentioning about 120V only being used for the low power circuits because of that wire size issue.So you can get 100a at 120v and 200a at 220v,
I'm really confused and don't understand what this means at all. Physically there can't be any such thing as a "single ended circuit". Circuit sounds like the word "circle" for good reason. All AC circuits must be a closed loop to have any current flow at all. So I am assuming that the phrase "single ended" is kind of a nickname for some way of connecting them. From the breaker at one end, what do the other ends of these circuits connect to for their return path?Ring mains start and end at the same breaker, single ended low power circuits are 16a max and lighting circuits are again single ended and normally 6a. All other high power circuits like showers, electric hobs, EV chargers are all single ended 32 - 40 amp.
...I'm really confused and don't understand what this means at all. Physically there can't be any such thing as a "single ended circuit".
Oh. Well, the terminology is just funny then. You say there is no loop back. But then you say the wiring runs have live, neutral, and earth. The Neutral IS the loop back. That's exactly how our 120V circuits are.You are very close on the understanding of single ended, it is when one end it attached to the socket and the other the breaker with no loop back, we have limits on how many sockets may be daisy chained like this. So we would run 3 core (normally 2.5mm) which would carry the live, neutral and earth so no "return" path is required, all EV charging points are wired this way.
Notice how there is no letter i after the v in mischievous?Now you guys should go back and forth on the proper pronunciation of aluminum.
You spelled it incorrectly. It's aluminium.......Now you guys should go back and forth on the proper pronunciation of aluminum.
The original model S was a 40a charger which needed a 50a circuit. If you got the double charger it was 80a on a 100a circuit.
The new S and all X's are 72 amp chargers which require 90a circuits.
Model 3 Long Range (all they are selling right now) units are 48 chargers which require 60a circuits.
So yes, there is no current production Tesla that can make use of a 100a circuit, but there are lots of them that can make use of a 90a circuit. I think you are not understanding that the 72a chargers require a 90a circuit which is just shy of the full 100a. I don't see how this is sneaky at all. They went from the base Model S having 40a of charging to it having 48a, and then they made the "fast" charging option only 72a vs 80, but if I am not mistaken, I think it is a software locked feature? So not a separate piece of hardware? (someone correct me please if I am wrong) I don't see how this is sneaky in any way...
I personally would probably just do the 100a and be future proofed. Also, you can hook multiple Wall Connectors to the same circuit and have them share the capacity...
