Model S internal charger - No Longer Available
Discussion in 'Tesla Parts for Sale' started by [email protected], Mar 17, 2015.
  1. firstpl@gmail
    NY
    Tesla Model S internal charger, comes with alternative cooling lines, perfect condition.
    List Date: 3/17/2015
    For more info, click here to view the original listing: Model S internal charger
    This item is no longer available.
  2. scaesare
    scaesare Well-Known Member
    NoVA
    Is this a foreign market charger?
  3. pgiralt
    pgiralt Supporting Member
    Cary, NC
    Are there really different chargers for US and abroad? Looking at the label, it looks like it can take pretty much anything you throw at it - anywhere from 85 to 300 VAC with a frequency of anywhere between 45 - 65 Hz, plus it says it can accept both single phase and three-phase.
  4. firstpl@gmail
    NY
    Its from a US car but I think its the same charger for every Model S, just the wiring and charger junction box is different
  5. scaesare
    NoVA
    The cars for foreign markets where they have 3-phase power (Europe, etc..), have chargers that each contain three 16A chargers. This is opposed domestic versions that contain one 40A charger.
  6. firstpl@gmail
    NY
    Well from what I see the charger is actually 3 phase but for the US market the junction box combines all 3 phases to 1
  7. samcarney
    samcarney Sam C
    Great Lakes, Sonoran Desert
    Price reduced on Tesla website. $2000 new with installation.
  8. markb1
    markb1 Active Member
    San Diego, CA
    I don't think you can just connect the phases together into one phases, so it would have to be more than a junction box.
    Anyway, from my understanding, the chargers are different, depending on if the car has a Tesla-proprietary connector (as in the US), or a standard-compatible type 2 inlet (as in Europe). And the old 120 kW superchargers used a stack of 12 US-spec charger modules, 4 modules per phase. The new 135 kW use the Euro-spec 11 kW charger modules, with every module connected to all three phases.
  9. scaesare
    NoVA
    Correct, you can't just bridge all three A/C input phases together. BOOM.
    The DC OUTPUT of the 3 sub-chargers it's what's combined, but I believe that's within the main charger housing. If you have two chargers installed in your car, then those outputs may be combined at the junction box.
  10. firstpl@gmail
    NY
    Well of course you can't bridge three phases when you actually have three phases. The charger accepts input from 3 AC lines and in the US version the junction box bridges those inputs into one inlet from the charge port. The charger doesn't care if the 3 phases have a shift or not.
  11. markb1
    San Diego, CA
    #11 markb1, Mar 17, 2015
    So, you're saying the one phase from the charging inlet is split into the three phase inputs of the charger? Possible, I guess, but certainly old cars did not have three-phase chargers.
  12. scaesare
    NoVA
    Just responding to what you wrote:
    A single phase connected to three inputs in parallel is not "3 phases".
  13. firstpl@gmail
    NY
  14. scaesare
    NoVA
    #14 scaesare, Mar 17, 2015
    I think you are misunderstanding my point. I'm not doubting all three inputs are bridged together in parallel.
    What I'm pointing out is that you aren't connecting "3 phases" together... you are feeding that set of bridged inputs with a single phase, exactly as that picture illustrates.
  15. pgiralt
    Cary, NC
    Another thing that might be useful to know for a prospective buyer is whether this was the primary or secondary charger in the car. The chargers get programmed by Tesla to be one or the other and can't be swapped without reprogramming (which I'm assuming only Tesla can do).
  16. firstpl@gmail
    NY
    This is the secondary charger
  17. Lloyd
    Lloyd Well-Known Member
    San Luis Obispo, CA
    I beleive you will also need a software upgrade from Tesla to use the second onboard charger.
