I don't think they are directly cooling the rotor, as you say it's difficult. I think some other companies, maybe Remy, are trying oil cooling the rotor in some way.Also (separate question) - how do you effectively cool the rotor? It should look similar in concept to the stator -- copper bars (instead of multiple distinct windings) embedded in steel laminations. You don't want liquid in the rotor/stator gap (too much drag). Is it worth trying to get liquid into the rotor somehow (hollow axle etc)? I doubt it. I guess cooling around the bearings/axle on either side of the motor would have to do...
Nice find TEG!
A rotor assembly cooling system (100) and method of using same are provided. A portion of the rotor shaft (103) is hollow, the rotor shaft including an open end (107) and a closed end (105). A coolant feed tube (109) is rigidly attached to the rotor shaft (103) using one or more support members (111), thus causing the shaft and the feed tube to rotate at the same rate. Coolant is pumped through the feed tube until it exits the end of the feed tube and flows against the inside surface of the closed end of the rotor shaft causing the coolant to change direction and flow back through the coolant flow region, this region being defined as the space between the outer surface of the feed tube and the inner surface of the hollow rotor shaft.[/url]
Well, you know what they say about people who 'assume'.. :wink:Is it worth trying to get liquid into the rotor somehow (hollow axle etc)? I doubt it.
There are no transistors in the inverter, its all done with IGBT. 900A for standard, 1200A for performance. Motor spins up to 16.000 rpmMy understanding is that it is bigger wires and a larger inverter. The inverter holds the transistors that drive the wires. Motor is the same.
Tesla Model S Beta 1: A glimpse of the future from the passenger seat | The Car Tech blog - CNET Reviews
For some reason I cannot imbed the pic in the link.
While looking at the pics of the drivetrain from the skateboard mule, I have noticed something interesting. The Model S motor case seems to be integrated(welded) onto the differential case. That can't be a very service friendly proposition, as you would almost certainly need to disassemble the differential to do any work on the motor. I wonder if the production motor would be the same setup?
Another thing I noticed from the very first pic in this thread of the Model S motor is, Tesla seems to be using a front motor bearing that is oil lubricated by the differential oil. Not that that is a very bad thing, but don't sealed motor bearings have much longer longevity? I wonder if these are cost cutting measures?
Discuss.
