Model S: No Spare Tire
Discussion in 'Model S' started by pkondaka, Feb 21, 2017.
Tags:
  1. pkondaka
    pkondaka New Member
    Ashburn, VA
    Tesla doesn't have spare tire and I have tow my car to nearest auto center to replace my tire. Ridiculous.
  2. Derek Kessler
    Derek Kessler Active Member
    Cincinnati
  3. habanero69
    habanero69 I Dont Need Cialis. I Drive an EV.
    FLorida
    1) invest in a tire inflator w/sealer for those cases where it would work, or
    2) invest in a car that comes with a spare
  4. LuPapa
    LuPapa Member
    Houston
    Inflators kit with the sealant or you could swap your tires for run flats and just drive to the closest tire shop and buy a new run flat.
  5. CLLACAB
    CLLACAB Member
    Simi Valley, CA
    I purchased a tire plug repair kit off of Amazon and have a compressor as an emergency measure in case I am not within a reasonable distance of a repair facility. I also have a Volt - no tire there also....The manufacturers claim weight saving....but it is really about saving money...
  6. dgpcolorado
    dgpcolorado high altitude member
    The Western Slope, Colorado
    Some of us carry 12 V air pumps and plug kits or sealer goop. A very few of us put together our own spare tires. I carry a spare and jack on long road trips and rely on a plug kit for local driving. Some of the places I drive, even if I did have a cell phone signal, a long tow to the nearest town likely means a tire shop that doesn't have the right size tire in stock. I'd rather fix it myself or put on the spare and be on my way.
    I'd guess it is different for the many Tesla drivers who never get very far from a Service Center. For me, even at home I'm nowhere near a Service Center (338 miles) or a tire shop that has the right tires.
  7. johnnyS
    johnnyS Member
    Not a new subject--use the search function to find prior threads on this subject. I use to carry a full size spare in my frunk of my old model S. Now that I have upgraded to a 90D with a smaller frunk the 19" spare is in the garage. Of course I have had multiple flats in my model S that does not have a spare. For road trips now I will throw the spare in the rear. I carry a 12V compressor all the time.
    I had a leak in Estes Park Colorado last year. The guy that fixed it told me he has had a number of calls from luxury car owners who have a flat who did not realize they do not have a spare.
    • Disagree x 1
  8. jelloslug
    jelloslug Active Member
    Greenville, SC
    I have not had a car that came with a spare tire in years. How could you possibly not know this about a car that you own?
    • Like x 4
  9. daniel
    daniel Active Member
    Spokane, WA
    It is a pet peeve of mine. First they gave you a little "doughnut" spare that's no good at highway speed. I once had to drive about 50 miles on one of those, holding up traffic on the two-lane road because I could not drive at the speed limit. I pulled over every chance I got to allow cars to pass, but it was still horrid. Now they don't give you a spare tire at all. Not just Tesla. You're hard pressed to find a new car with a spare nowadays. Tires are better than they used to be, however, and flats are less common than when I began driving.
  10. Naonak
    Naonak Member
    Kansas
    I've always taken the spare tires OUT of my cars. In 30 years of driving, I've had exactly 3 flat tires away from home.
  11. SabrToothSqrl
    SabrToothSqrl Active Member
    PA
    I've driven well over 450,000 in my life and never had a flat. Ludicrous.
  12. Skotty
    Skotty 2014 Model S P85
    Kansas City, MO
    #12 Skotty, Feb 21, 2017
    Honestly, there must be better roads in other parts of the country, as I tend to get about 1 flat every year. Just had an unfixable flat on my P85 two weeks ago. Before that, in the last few years, I've had 2 flats on my Chevy Volt, and 2 on my Ford Escape as well.
    A couple of ideas. I'd have links, but I'm away from home, so I will have to come back later to add the links.
    First -- spare tire options. Of course, you can try to get a full size spare off of someone else who has replaced his or her wheels and tires, or just buy a new one out right to keep at home or in the car. There are also some compact spares that will work. One in particular from a BMW outlet, and they note right on their web page that a lot of Tesla drivers use it as a spare. I believe it's a perfect fit and appropriate circumference, though you should also buy the hub ring (I think it's called) which they make note of for Tesla drivers right on the page. They also sell a tote for it, which is nice. It will fit in older style frunks, if you are hoping for a frunkable spare.
    Second -- portable jacks. Sorry, I have nothing useful to share on this. Need to do some research.
    Third -- home jacks and jack stands. Just about any floor jack will do, but I highly advise you spend some money on a set of JackPoint jack stands. They are big and expensive, but they allow you to put a stand on the same point as the jack, which is otherwise a huge problem on a Model S (you can't jack it up and then put a regular jack stand under it, as their is only a single jack point per corner and it's small).
    I haven't done any of this yet, and I paid for it when I got a flat a couple of weeks ago. Luckily, it was close to home, and I had the car at home, but without a spare and without a JackPoint jack stand, I had no way to remove the wheel myself to get the tire replaced. I had to have Tesla bring in a flat bed tow truck to tow it somewhere to get the tire replaced. Ridiculous, indeed. But fixable with some money and forethought. Or just rely on road side assistance like most people probably do.
  13. Max*
    Max* Charging
    NoVa
    Wait, what? The Model S has no spare? I want my money back!
    • Funny x 4
  14. ChrisPDX
    ChrisPDX Member
    Hillsboro, OR
    I've had about 8 flats in about 16 years. Never once needed a spare. Every time I get a nail or screw in my tire, it's been a slow leak. Just connect a 12v portable compressor and fill it up. I can then drive like normal to the nearest tire place. For fast leaks, I also have the slime stuff, however I've never needed it. Only if I have a total tire blowout would I need a tow. But those are usually caused by driving extended periods on low tire pressure. With the tire pressure monitoring system, that should never happen.
    My one car that actually has a spare, I've pulled it out to make room for storage. No regrets so far.
  15. kort677
    kort677 Banned
    florida.
    not a bad troll for a first message.
  16. mattr2
    mattr2 Member
    Orem UT
    I hit a pothole in Jan, blew the Tesla tire to pieces. Had to call Tesla support, they sent a tow out right away so it could go to my fav tire shop.
    My advice, get run flats if you are concerned.
    These heavy beasts also have trouble stopping on icy roads, best to get a set of winter tires and a set of spring-fall tires co spidering the repairs costs if you hit ANYTHING. Save yourself months of waiting and a fortune to repair. Trust me, tires are cheap.
  17. bktiger86
    bktiger86 Member
    West Covina, CA
    I used to have a car that have a spare tire in the trunk, but it was literally never used. One time I decided to check on the spare tire, it was totally destroyed because it was never maintained. What a waste in the trunk + the weight. I pretty much just signed up for AAA plus member and they can tow my car 100 miles anywhere. I'll just take the risk.
  18. daniel
    Spokane, WA
    The last time I got a flat tire (probably 6 or 7 years ago or thereabouts) I was heading home from my hiking trip in Canada. I had no cell phone coverage, and it was a Sunday when nothing was open. If I had been a member of AAA it would have done me no good without a cell signal. If I'd been in a Tesla with Roadside Coverage, it would have done me no good, same reason. I was in the Prius with the crappy little doughnut spare, but at least that got me home.
    Had I been in a newer car with no spare I'd have had to hitchhike back to town (about 50 miles), then tried to find a shop that was open, or leave my car with all my hiking gear in it overnight on the side of the road until Monday morning.
  19. TexLaw
    TexLaw Member
    Bellaire, TX
    Spare tires are going the way of the dodo in favor of much better options.
  20. Shorty
    Shorty Member
    Victoria BC
    Even cars that I have purchased that have spare tires have 'emergency spares' which are not full size and which are usually recommend for 40-50 miles or less. If you are travelling, the issue isn't the 40-50 miles to a tire shop, it is usually finding a shop that actually stocks a tire that fits our cars!
