(Speculation hat on) Maybe...a future Telsa "solar roof option" will only be used to power the "cabin overheat protection" feature for as long as the sun is shining (which is the only time you will need it) without drawing any power from the main battery, so that feature can operate indefinitely. The Prius has a similar option.We know it's possible to put a solar roof on a car.
We also know that there is no reason to do so, ever. There's simply not enough solar radiation hitting the roof of your car to make any meaningful difference (even if solar cells were 100% efficient, which they aren't)
So now we get into the same situation for existing orders as happened with AP. Please post if anybody hears from their D.S. whether it will be possible to switch from old sunroof to new all glass roof (same price) without change fee.
Why would you want a solar roof? It will be less transparent and you'll be barely lucky to get a mile or two out of it in a day of full sun. It would raise costs for no benefit.
Added weight, raised CG, hotter cabin, can't be opened, more expensive, less efficient, expensive to fix, and possibly less safe? For me personally, it's not an enticing option.
I would, however, like to see it be electrochromic, going from transparent to opaque at the touch of a button.
I should have clarified: I'm comparing to fixed body color roof, not pano.Added weight - do you have something to substantiate this? I'd imagine without an opening mechanism it would weigh less.
Hotter cabin - from the removal of the pillar? That's hardly a measurable increase.
More expensive - it's $500 less
Less efficient - there's no way smooth glass is going to be less efficient than a surface with seams. Opening a sunroof is definitely less efficient, though.
Expensive to fix - a solid piece of glass vs an equally large piece of glass with an opening mechanism..I don't see it
Less safe - Elon tweeted that the structural changes made it more safe and it received a 5+ in rollover
There will, however, be less noise and less potential for leaks. It all comes down to what options you value. To each his own!
"Super expensive" vs. just plain old "expensive": "no" to the former, but that doesn't necessarily mean the latter doesn't apply.
I wonder if Tesla will switch over to the new steering system on all new cars,
What new "steering system" are you talking about?
A thread was started 3 weeks ago to discuss the new Model S glass roof option, see Model S now has glass roof option..I've just ordered a S with all-glass roof, which I think looks really good. The glass extends all the way to the top of the windscreen and to the sides, so there is quite a lot more than with the sunroof, and there is no bar across the centre, so the view from the rear should be better
