Model S Overall Thermal Management
Lensman
5
0
Hertfordshire, England
Hello all, long time lurker, however thought Id chime in on this one, I spotted this image from another forum post, it does seem to concur with what has been said here about running the cooling loops in either parallel or series arrangement:
Hello all and one btw... :)
stevezzzz
R;SigS;P85D;SigX;S90D;XP100D;3LR;YLR
Nov 13, 2009
6,100
121
Colorado
Welcome to the forums, Lensman. Yours has to be the most interesting first post I've seen yet. What else ya got? :biggrin:
scaesare
8,187
12,928
NoVA
Thanks for contributing that pic, Lensman... yours shows the system in series mode with the entire loop red, whereas the pic I posted in the first post has the system in parallel with the drivetrain loop red, but the battery loop green.
Also, several temps that are displayed in one pic aren't in the other.
Interesting...
paco3791
TMC OG
Nov 10, 2006
366
7
Antioch, IL
So am I reading these pictures right? There doesn't appear to be a Cabin specific resistive heater shown here. Just a heat exchanger link to the battery and/or drive unit coolant line which can be heated by some combination of the Drive unit operating, battery discharging, and/or active use of the battery heater by the system. But since a cabin specific heater wouldn't have to be linked to any of the "liquid" systems shown here and could just be as simple as a toaster and just heat the air directly I suppose it may not make sense in this particular diagnostic view.
Reactions: Snowstorm
Kalud
1,056
285
Montreal, QC
Yes it looks like the cabin heater is just a "toaster", its called a Air PTC in the picture and Air PTC is just that, a heater element.
Something like this, but a 400V / 6000W version: http://www.ptc-heater.com.tw/PTC_heaterFan_eng.htm
scaesare
8,187
12,928
NoVA
That's my understanding as well. It also meshes with my experience when the car was new... you could smell the oils etc.. cooking off the restive elements when the heater was used for the very first time... much like if you get a new space heater, etc...
apacheguy
S Sig #255
Oct 21, 2012
5,071
1,238
So Cal
Here is the same picture from 5.12; the target temps on the battery have changed a little...
You know, I've been thinking about this. 40 C to 30 C for the passive cooling target is a huge change, much more than just a little. Might explain why newer packs fair better in degradation analyses.
Tech_kid
New Member
Jan 4, 2020
2
0
Germany
Hi guys,
I am quite new to this forum and have been looking for some detailed information about where all the thermal sensors around the drivetrain are attached. I couldn't find anything more related to it. Could you please link me if this has already been written somewhere?
Thanks in advance
Tech_kid
New Member
Jan 4, 2020
2
0
Germany
Thank you for your answer.
They told me that the sensor is located in the stator and that there is only one per motor.
Sadly that doesn't really help much, because it's not very specific and I got several data for motor temperatures that imply that there are more than 2 motor temperatures (one per motor) which are sent via the CAN BUS and I can't identify which belong to where. Respectively which are supposed to be the "correct" ones from the single temperature sensor in the motor.
Kalud
1,056
285
Montreal, QC
Hi there,
Slave (front) Drive Unit is on message ID (decimal) 773
Mater (rear) Drive Unit is on message ID (decimal) 774
There are multiple temperature values in each of those: DC Capacitor, Heatsink, coolant inlet, inverter, circuit board, stator.
Hope this helps ;)
