I stand corrected. What does the vacuum system run?
The power brakes for one. With the car on and sitting just pump the brake pedal a few times. You will definitely hear the vacuum pump.
Hydraulic lines to push on the pads, but a vacuum booster to make pushing the pedal easier...
It wasn't all roses, but I will spare you the details.Nice - Magna supplied parts for the Roadster! It's a great Canadian company that I happened to buy shares in a while back because they are partnering with Ford for their BEV - didn't realize that there was a Tesla connection, too.
...The steering in normal and has electric assist, the P brake is an electric solenoid that pulls a cable. the brakes appear to be normal hydraulic electric-assisted, the accelerator is most likely a standard HEPI (Hall Effect Pedal Sensor), that's a magnetic sensor. There are e few hydraulic brake distribution blocks in the motor compartment...
...The brakes have a motor mounted in a booster assembly. There is a stroke sensor in the booster assembly to read how fast and hard pedal is applied. From the video I watched at work it shows a "cooprative" brake system. It starts with mechanical brakes switches to regen then back to mechanical brakes at final stop...
