Model S (Performance edition) 1/4 mile time
Discussion in 'Model S' started by William3, Mar 7, 2012.
Tags:
  1. Lloyd
    Lloyd Well-Known Member
    San Luis Obispo, CA
    I would think that with the low CG, and little body lean that all 4 wheels are going to be firmly in contact with the pavement during the skidpad test, resulting in higher numbers than we are used to seeing. I expect slalom speed to be impressive also. Can't wait for Roadster 3.0 !
  2. AnOutsider
    AnOutsider S532 # XS27
    You're not the only one... Hope it kicks a$$ in design, performance and tech
  3. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    Yes if the car can keep more weight on the inside wheels you'll get a bit more grip.
  4. TEG
    TEG Teslafanatic
    The Wrightspeed X1, which you could almost call the original Tesla Roadster prototype has exceptional handling. It really is limited by the tires and road conditions. It can do 1.2g+ around corners...
  5. Zextraterrestrial
    Humboldt/Los Altos
    you can get an old 914 to do 1.2g+ also w/ 245 on rears and 225 on the front. The weight distribution of the car makes a bit of a difference in handling too- 34/66 for the x1 vs 46/54 of the 914 (I'm not sure what the 'best' ratio is) The S should be awesome!
    1/4 mile S time I am upping to better than 12s w/ the sport TC and a 'light' driver + maybe spare tire removed, Is there a spare?
  6. AnOutsider
    No spare as far as anyone can tell
  7. spatterso911
    spatterso911 P100DL - Raven
    Rancho Cucamonga, CA
    Not sure I could see a sub 12s time in 1/4 mile. Most sedans in this class at 0-60 can hardly do better than 13 sec and I think that as you wring the electric motor out, HP and TQ drop off. I still cannot imagine this car doing much better than 12.6 sec. Sure wish I could see the power curves for this car. It would really be foretelling.
  8. Zextraterrestrial
    Humboldt/Los Altos
    Ya, i think 12.6 is a pretty realistic #.
  9. rabar10
    rabar10 Model 3 >> Focus Electric
    Indianapolis, IN
    #49 rabar10, Mar 12, 2012
    Revised estimate. I actually put effort into this one...
    • Took the earlier Model S max torque chart and entered it into Excel to get torque/HP at RPM.
    • (EDIT gear ratio is posted as 9.73 on TM's site, adjusted below) Came up with a gear ratio guess of 10.3 based on outer tire diameter and max speed requirement to get torque/HP at speed.
    • Grabbed the Roadster Efficiency and Range spreadsheet from JB's blog post, which has data in 2 MPH increments
    • Made "Model S multiplier" coefficients for each of the losses there (ancillary, tires, aero, drivetrain). I based the tire loss multiplier off of the weight difference (assumed 4225 lbs for the Model S), and gave a best-guess shot at the others.
    • Played with these numbers until I got the 65kWh range number around 230 miles at 55mph.
    • Calculated kinetic-energy change required for each 2MPH increment based on vehicle weight (momentum, basically).
    • Subtracted the steady-state losses at each speed from the max power available at that speed
    • Averaged the power between each speed increment, and divided by the KE change to get a time estimate per 2MPH increment.
    • Add the times up, double-check the ET at 60mph (I get 4.46 sec, sweet)
    • Calculate distance per increment and sum that as well, and I get a quarter-mile time of...
    12.78 sec @ 114.6 mph
    EDIT: with proper 9.73 gear ratio, I get 12.95 sec @ 114.6 mph.
    EDIT 2: adding 5% power-to-pavement losses at max power, I get 13.24 @ 112.6 mph. Revisionist predictions are fun!
    I'm such a nerd. :rolleyes:
  10. AnOutsider
    Good work man, way more than I could have done. Wish we could "pin" this post and reference it for later. Would be cool to see how close you came.
  11. spatterso911
    Impressive deductions. Will be curious once real world dyno and track data emerge to see if your numbers are in the ball park.
  12. ckessel
    ckessel Active Member
    I haven't been following the thread much, but the Specs page says "Single speed fixed gear with 9.73:1 reduction ratio". Are we talking the same gear ratios or is your 10.3 some other type of gear ratio?
  13. rabar10
    Indianapolis, IN
    As will I!
    Just added a max-power loss coefficient to my spreadsheet since the torque/HP curve is at a motor dyno level.
    If you assume 5% losses in getting max power to the asphalt (on top of the steady-state losses to maintain a given speed, which is already estimated), you get 13.06 @ 112.6mph.
  14. spatterso911
    I'm thinking that that is a lot closer to my "homeboy" estimate of low thirteens and around 105-110 mph.
  15. rabar10
    Indianapolis, IN
    Good catch. Will adjust for that. Top speed looks to get closer to 140 if it lets you get to 16k RPM and you're on the 245/35R21 tire that TEG got a picture of (27.75-in diameter)
  16. Lloyd
    San Luis Obispo, CA
    What... Only two decimal places!! Couldn't you be more accurate!! :tongue:
  17. rabar10
    Indianapolis, IN
    #57 rabar10, Mar 12, 2012
    Corrected above post with proper 9.73 gear ratio.
    • Without modeling any max power losses, I get 12.95 sec @ 114.6 mph. But my modeled 0-60 drops to 4.7 sec.
    • With a 5% power-to-pavement loss at max power, I get 13.24 @ 112.6 mph. Modeled 0-60 drops further to 4.9 sec.
    Based on the 0-60 times being off now, I'm willing to bet that the torque number for performance S has gone up from the quoted 415N-m number to around 455N-m, with the knee at 6300RPM or 52mph. I think "just under 13" is still the best guess for now.
  18. ferrarimanf355
    Jupiter, FL
    I'd be happy if it's on par with the 2012 BMW M5. Any quarter mile times on that one?
  19. stopcrazypp
    stopcrazypp Well-Known Member
    The official BMW sourced specs, put it at 0-60 in 4.4 secs and 124 mph in 13.0 secs (which I assume corresponds to the 1/4 mile). So it seems it will be almost exactly the same as the Model S Performance in terms of "official" specs.
    http://www.topspeed.com/cars/bmw/2012-bmw-m5-ar100010.html
    Car and Driver did clock it at 0-60 in 3.7 secs and 1/4 mile in 12.0 [email protected] But they did need a couple of tries plus launch control (which the tester noted was really hard to engage) to accomplish that type of acceleration. In the Model S, you just floor it, no fiddling with the launch control required (this is off topic, but I wonder if a "launch control" mode is possible for the Model S and if it would help squeeze some more time out of the launch).
    http://www.caranddriver.com/reviews/2013-bmw-m5-road-test-review
    So I suspect unless the driver knows how to use the launch control well in the M5, a race between the two will be pretty close.
    Although the new M5 does have higher peak torque (680 N·[email protected],500 rpm) and peak power ([email protected],000 – 7,000 rpm) . Curb weight is 1,945 kg (4,288 lb) so it might have a weight advantage too.
  20. Lloyd
    San Luis Obispo, CA
    Found on the BMW blog HERE 3.7 seconds
