Hey guys,
Just a little self-centered update for you all from MPP:
Happy to announce that our first batch of 400MM big brake kits
will be shipping out directly from Girodisc this week, ahead of schedule! So if you haven't already made an order and want a pair before the holiday break, now might be a good time
The 2pc rear rotors and OEM fronts are coming along as well and we should have prototypes of those here early next week.
The master cylinder brace has been awesome, the amount that the OE firewall flexes is quite significant. We'll do a test and post it to show just how much the firewall flexes. It is certainly contributing to that long pedal feel that the car has (especially with the low friction OEM pads that require a lot of effort). We're looking for beta testers of the MC brace, so if you're interested shoot us a PM or an email. We want to average out dimensions over a number of vehicles.
In addition, we've been prototyping lines, so that is something in the pipeline that will be released in the coming months.
We're really proud to say that we've made some significant strides in the brake department on the Plaid, the pedal feel is finally up there with what you would expect with the right pads. We have some prototype pads that I can't talk too much about at the moment, but they are working quite well (as evidenced by the data below!)
Here are results from our multi-channel IR brake temp test comparing the 400mm BBK to the OE rotor, both sides using the same prototype pads. The significant thing to note is how much cooler the MPP rotor runs over the duration of the test, this is because once the OEM rotor heat soaks, it takes much longer for it to cool down.
A description of the graphs above:
Top: A rainbow chart of the MPP 400MM rotor (Brake Temp Left Sensors 1-6). The top of the graph indicates the outside of the rotor, and the bottom of the graph indicates the inside of the rotor. You can observe that the inside always runs cooler because that is where the cool air enters the center vanes. This is evidence of the air being pumped through the rotor.
The range of the color graph is 150C (dark blue) to 850C (dark red).
Rotors can be seen glowing at ~520C in the day - so wherever you see yellow-red in the graph above, the rotors were glowing!
Middle: A rainbow chart of the OEM 380mm rotor (Brake Temp Right Sensors 1-6). The rotor heats evenly over the surface and retains its heat much longer as it does not have a way to actively cool itself.
Lower: Vehicle speed to help you understand the drive cycle. Full throttle acceleration between 80-150km/h repeatedly, specifically in the latter part of the test. Acceleration Longitudinal Car is zoomed in to the range of -0.8 to 1.4G's of braking. The green horizontal line indicates 1G of braking, so you can easily observe how aggressive the braking events were. Specifically, at the end, these were all full ABS braking applications.
So other than looking awesome, the rotors make a very significant improvement to helping the brake system run cooler as we claimed.
