Model S Plaid chrome delete discussion
ekimsurfer
Slingshot Engage
Oct 9, 2017
26
23
Florida
Got my plaid yesterday. Wanted to start a discussion about what everyone is doing for the emblem chrome delete and the “Plaid”’badge chrome delete. Was going to potentially wrap them all in gloss black versus a plaid wrap. I’ve seen some talk of carbon fiber wrap. Any thoughts?
Anyone remove the front emblem? It doesn’t slide off after removing the 2 top screws. Seems to have another secure point in the center.
There is one you have to access from the rear of the emblem where you remove the front most top engine cover to access it. Not sure if words gets it across, but you can from the backside of the "T"
Reactions: C4sxm5
DaylightWT
Former Vendor
Local Vendor - SoCal
Nov 8, 2021
17
4
Ontario California
The front emblem has 3 screws 2 on top and 1 behind the T. The back T is held on by double sided tape. Sand them down with 320 grit sand paper wipe down with alcohol and spray a light coat let dry and then do a regular coat. Do about 3 coats. As for the back T buy some double sided tape from Walmart and apply to the back of the T and stick back on. Use tape to mark where the T position was.
