green1
What makes you think the pack can take more than the 60kW being used now? keep in mind that the superchargers can only do 120kW, and only if the pack is basically empty. When the pack is near full it uses a LOT less at a supercharger.I'm certainly expecting that from Tesla. A P85D should be capable of about 220kW of regen above the critical speed, if the pack can take it (the 60kW the car permanently does on the rear motor, plus the front motor running at its 160ish kW maximum.) That's almost half of a full on panic stop, if I did my math right - and still less load on the cells than the Volt does every day (less than 3C - the Volt's 60 kW limit is almost 4C.)
Even if Tesla doesn't want to exceed the supercharger limit, they could double the regen when the battery is in the range where it can take it - and with the new systems, seamlessly replace it with friction braking when the battery can't take the power.
Walter
You wouldn't want your regen to brake a different amount depending on the battery level, you want it to be predictable, which means you make it the max that the pack can take when near full, not the max it can take at empty.
Likely the battery is the limiting factor here, you don't want more than 60kW when the pack is near full or you'll damage the pack. and you don't want it to vary with charge or it won't be predictable in normal use.
