SO, if I wake the car at 10pm and it is not plugged in and then I check if the car is awake in 11 minutes, if it is asleep, I have no way of knowing if it got plugged in during the 11 minute wait.... But if I check the car itself within the 11 minutes I will keep it awake.....The keepalive timer is set to 10 minutes. So pulling data with a frequency of every 10 minutes or less will keep the car awake.
Can't get the streaming api to work either on Model 3 (2018.21.9 75bdbc11)
Looking through the APK, I found a "new" streaming endpoint:
Code:StreamingServerEndpoints={LOCATION_STREAMING:"streaming/",AUTOPARK_SUMMON:"connect/"}
but I am unable to connect, server seems to not be able to connect to the car.
Code:{"msg_type":"data:error","tag":"${vehicle_id}","value":"disconnected","error_type":"vehicle_disconnected"}
If anyone wants to try the new endpoint on their Model S or X I can send some sample code over
I can confirm another Model 3 that returns the same result and also a Model S that doesn't work with the old streaming endpoint is also receiving the vehicle_disconnected message!
Surely these would still have the location working in the Android app which uses this data stream, so there must be something we are missing.
{"response":{"reason":"invalid_limit","result":false}}
{"limit_mph":80}
{"limit_mph":80.0}
Still getting invalid limit.@dpskipper , limit_mph must be a double. Try the following:
To your second issue, Speed limit mode is different than how valet mode does it. You must supply a new pin or the correct pin when enabling the mode, disabling the mode, or clearing the pin.Code:{"limit_mph":80.0}
The only command that doesn't require a pin is the speed limit set limit command, however this command requires speed limit mode to be disabled.
Yes I actually managed to figure this out myself in the end.
It works fine for me. Model S 2018.21.9
{'msg_type': 'data:subscribe', 'tag': '<vehicle ID>', 'token': '<base64 encoded email:token>', 'value': 'speed,odometer,soc,elevation,est_heading,est_lat,est_lng,est_corrected_lat,est_corrected_lng,native_latitude,native_longitude,native_heading,native_type,native_location_supported,power,shift_state'}
Disconnected!
VERB 1: Error: NoDataAvailable
Can you provide a plaintext example of this subscribe request? I'm unable to get my new Model S on version 2018.26 3bbd9fd to connect with the old stream API. I'm trying to use the new stream API and I'm sending a request like:
Code:{'msg_type': 'data:subscribe', 'tag': '<vehicle ID>', 'token': '<base64 encoded email:token>', 'value': 'speed,odometer,soc,elevation,est_heading,est_lat,est_lng,est_corrected_lat,est_corrected_lng,native_latitude,native_longitude,native_heading,native_type,native_location_supported,power,shift_state'}
When I try to send that with wsta I get:
Code:Disconnected! VERB 1: Error: NoDataAvailable
Ok cool. I thought I heard a bit back that the API was just not working at all for 3 -- like, server-side. Maybe I misunderstood and/or it was resolved a bit back.What are you looking for? It's almost the same as Model S and X. It just works![]()
