Model S REST API
GPinzone
317
168
Ronkonkoma, NY
What's the general workflow for issuing commands? I'd assume it's:
  1. Login
  2. Get bearer token
  3. Cache token until it expires
  4. Get Vehicle ID
  5. Wake up vehicle - Loop with small delay until status changes to "online"
  6. Get status / issue commands
I've noticed that certain status calls like Driving and Position and commands like HVAC On will fail unless the car is awake. However, those calls will wake the car without having to issue the wake vehicle command. Therefore, is the wake up vehicle command necessary? Is it okay to just loop-with-delay-on-failure those commands that need the vehicle to be awake?
wayner
3,804
1,382
Toronto
Does anyone have the API command to open the trunk? Presumably that has just been added as you can now do it from the app.
Dazboj
86
25
UK
Does anyone know what the rate limit is?
If you hit an endpoint every second for a few minutes are you likely to get temp blocked?
GPinzone
317
168
Ronkonkoma, NY
I didn't think that the Tim Dorr docs were being updated anymore. Good to know. But the command is supposed to be" https://owner-api.teslamotors.com/api/1/vehicles/vehicle_id/command/trunk_open" with the parameters vehicle_id and which_trunk. But where do you put the which_trunk parameter in the call?
According to the link I posted, it would be:
https://owner-api.teslamotors.com/api/1/vehicles/555555/command/trunk_open?which_trunk=rear
Where the 555555 gets replaced with the real vehicle ID. I've never tried it.
wayner
3,804
1,382
Toronto
Thanks guys - whoever has control over the docs should then fix the example as it as it is wrong as it doesn't include the which_trunk parameter.
dpskipper
Developer
Aug 4, 2016
187
44
Australia
Can anybody else confirm this for me?
Sending a POST request to /api/1/users/keys with the following JSON payload:
Code:
{"public_key":"some gibberish"}
Should break the mobile app so that it can't load vehicle anymore and just says "Server Error". Forcing you to sign in/out again.
insaneoctane
3,369
5,183
Southern California
As of V9, the Model 3's are now populating a charge_state attribute called "est_battery_range". Before V9, this field was always empty...I suspect S/X have had these populated already. But now that I'm seeing this new data, I tried (unsuccessfully) to find in the documentation the detailed difference between these 3 attributes:
  • battery_range // rated miles
  • est_battery_range // range estimated from recent driving
  • ideal_battery_range // ideal miles
I'm confused particularly because battery_range and ideal_battery_range are IDENTICAL to two decimal places after 10K miles on my Model 3. Any insight beyond the documented comments above would be welcome!
MDK
Aussie Member
Aug 1, 2013
421
156
Western Down Under
Does the model 3 (in-car display) allow you to switch between "rated range" (EPA) and "ideal range"? (also known as "typical range" (EPA) and "rated range" (NEDC) in Europe/Australia etc) like the Model S and X do?
They use different efficiency values (200Wh/km and 160Wh/km on my model S) so give different values in the car & via the API.
In this image "Ideal" corresponds to "Typical" in the car.
insaneoctane
3,369
5,183
Southern California
No, I don't think so. The only setting that I am aware of is percent battery vs miles.
ACDriveMotor
890
24
Seattle, WA
No pressure!
Last app update I dug into was 3.5.0 and it contained the new message center endpoints. These are important updates/notifications designated for your Tesla account, nothing too fancy.
Looks like 3.6.0 has a few more endpoints here:
  • Media Player
    • Toggle Playback
    • Previous/Next Track
    • Previous/Next Favorite
    • Volume Up/Down
  • Schedule / Cancel Software Update
  • Navigation Request
I can dig into the technical details on these here soon, but they're all pretty straight forward.
Are the new endpoints documented somewhere? I am looking for the format of software updates and nav request specifically.
Reactions: SG57
dailo
620
781
Bay Area
Does anyone know how to force the streaming token to refresh? I see that often times the token given doesn't work, but after waiting a while the new tokens that show up do work.
insaneoctane
3,369
5,183
Southern California
Anyway to check for an available update via API? I seem to never be around my phone in the late evenings but rather on tablets and laptops. I would like to automatically send an email to myself if an update is available.
dpskipper
Developer
Aug 4, 2016
187
44
Australia
The update is available message the phone gets is via GCM push notification.
If you dont want to register your computer as a device for push notifications the only way I can think to work around this is to compare your cars firmware version to a known higher version from ev-fw.com or something
SG57
Former Vendor
Jul 24, 2016
400
570
Spokane, WA
@ACDriveMotor & @dpskipper & @insaneoctane , tagging you three as you've all asked for details on the new APIs, so here ya go.
Navigation Request
Endpoint: api/1/vehicles/{id}/command/navigation_request
Type: POST
Request Body:
The request body is expected to have a type, locale, timestamp, and a 'value' containing a small bundle of extras shared to the app.
Code:
    "type": "share_ext_content_raw",
    "value": {
        "android.intent.ACTION": "android.intent.action.SEND",
        "android.intent.TYPE": "text\/plain",
        "android.intent.extra.SUBJECT": "Splash Down",
        "android.intent.extra.TEXT": "Splash Down\n11127 E Mission Ave, Spokane Valley, WA 99206\n(509) 464-9541\n\nhttps:\/\/goo.gl\/maps\/YiWSQFd4R9B2"
    "locale": "en-US",
    "timestamp_ms": "1538858755621"
The bundle of extras varies depending on the content shared with the app so is hard to explain. Here's psuedo-code of my app's exact replication of the official Android app's logic. This took a bit to reverse engineer fully and accurately but rejoice, it's all there.
Code:
request.value.action = intent.getAction();
request.value.type = intent.getType();
request.value.scheme = intent.getScheme();
request.value.data = intent.getDataString();
if (Intent.ACTION_SEND.equals(request.value.action) && request.value.type != null) {
    request.value.subject = intent.getStringExtra(Intent.EXTRA_SUBJECT);
    request.value.text = intent.getStringExtra(Intent.EXTRA_TEXT);
    if (request.value.type.equals(ContactsContract.Contacts.CONTENT_VCARD_TYPE))
        request.value.stream = {
            first_name = "###",
            last_name = "###",
            org_name = "###",
            phone_numbers = [ { type = "###", phone_number = "###" }, ... ],
            email_addresses = [ { type = "###", email_address = "###"  }, ... ],
            postal_addresses = [ { type = "###", address_string = "###", city = "###", state = "###", country = "###", postal_code = "###"  }, ... ]
Response: Typical response for a vehicle command, but you'll get an error "unsupported_input" if Tesla's servers can't determine a location to navigate to from your value in the request body.
Software Update Controls
  • Schedule Software Update
    Endpoint:
    api/1/vehicles/{id}/command/schedule_software_update
    Type: POST
    Request Body:
    Code:
    { "offset_sec" : 120 }
    Where offset_sec is how many seconds in the future when to schedule the software update, use 0 to install now.
  • Cancel Software Update
    Endpoint:
    api/1/vehicles/{id}/command/cancel_software_update
    Type: POST
Media Controls
All of these have no request body, pretty basic. You will get an error user_not_present if the main display in the car is off and you attempt to use any of these commands.
  • Toggle Playback
    Endpoint:
    api/1/vehicles/{id}/command/media_toggle_playback
    Type: POST
  • Next Track
    Endpoint: api/1/vehicles/{id}/command/media_next_track
    Type: POST
  • Previous Track
    Endpoint: api/1/vehicles/{id}/command/media_prev_track
    Type: POST
  • Next Favorite
    Endpoint: api/1/vehicles/{id}/command/media_next_fav
    Type: POST
  • Previous Favorite
    Endpoint: api/1/vehicles/{id}/command/media_prev_fav
    Type: POST
  • Volume Up
    Endpoint: api/1/vehicles/{id}/command/media_volume_up
    Type: POST
  • Volume Down
    Endpoint:
    api/1/vehicles/{id}/command/media_volume_down
    Type: POST
Lastly, forgot to mention there are some new vehicle data properties related to the new APIs as well.
Code:
vehicle_config: {
    can_accept_navigation_requests: true/false,
Code:
vehicle_state: {
    media_state: { remote_control_enabled: true/false },
    software_update: {
        status: "available/scheduled/installing",  // or null,
        scheduled_time_ms: 123421342134, // timestamp in MS, or null
        expected_duration_sec: 2700,  // expected install time in sec, defaults to 2700 sec (45 min)
        warning_time_remaining_ms: 1000000  // time until install, useless seeing as we're given a scheduled time already
