Model S road trip energy usage
Discussion in 'Australia' started by One Gear, May 2, 2015.
  1. One Gear
    One Gear Member
    Australia
  2. TesAus
    TesAus Member
    Sydney, Australia
    Another interesting and well put together video. Good to see that the trip can be comfortably made at posted speeds. Also encouraging to see that the trip planner was reasonably accurate.
  3. danielp
    danielp Member
    Sydney, Australia
    Nice write up. I've done the trip many times and those numbers are very similar. I also did the trip during the last big storm - that consumed another 12%.
    I am very curious to see how usage on this run as the weather gets cooler. The Goulburn SC may be useful then.
  4. One Gear
    One Gear Member
    Australia
    I too did a Canberra to Sydney run in the terrible weather - I'm hoping to have a video on that soon.
  5. moemoke
    moemoke Member
    Moe, Victoria, Australia
    I'm curious to know what you guys do with the regenerative braking settin when on a highway cruise, do you switch it off
    so you can lift of the accelerater and coast down the longer hills. Or is it better for range to leave the regen on a higher setting
    and not coast so much so that you can put some power back into the battery.
    It might be interesting to compare the two methods.
  6. TesAus
    TesAus Member
    Sydney, Australia
    I use cruise control and then the car uses regen as needed to slow the car to the set speed.
  7. Dborn
    Dborn Confirmed
    Sydney, Australia
    The car reports energy usage lowest when on cruise control. I have not been able to match it while I am in control.
  8. One Gear
    One Gear Member
    Australia
    I always have regen set to standard. It's hard to imagine driving without it now. As TesAus says, on road trips, cruise control takes care of it all for the most efficient energy use.
  9. moemoke
    moemoke Member
    In my ICE car it feels like the cruise control would use more fuel as it accelerates up hills and holds the set speed down hills
    where as with it off I can slow down a bit going up hills and creep over the limit going down hill and use that free speed for the next
    up hill or long straight. Maybe the Tesla cruise is a bit smarter than mine!
  10. MDK
    MDK Aussie Member
    Western Down Under
    The Tesla will also use more energy when you go uphill, but you get around 80% of it back when going down the other side.
    It means you can let the cruise control do its thing and not have to worry about energy use.
    Combined with the "traffic aware cruise control" you barely have to pay any attention to the speed at all, just focus on steering.
    Until the autopilot lane-keeping update comes through, then you don't even have to worry about that.. just observe and monitor :biggrin:
  11. One Gear
    One Gear Member
    Australia
  12. ZTrekus
    ZTrekus Member
    Sydney, NSW
    A very good video One Gear. I don't believe the P85D would have made it back to Canberra.
  13. baillies
    baillies Member
    Sydney, Australia
    Thanks One Gear, any range anxiety on the way back? 91% is cutting it a bit closer than normal, seems the Goulburn supercharger would be useful in a winter storm, hopefully they will cover it. Seems the range estimate did not factor in weather. I wonder if the weight also has an impact, especially up hill, maybe useful to be able to add weight into the estimator. I guess with air suspension Tesla maybe able to get an estimate of weight through a pressure sensor somehow.
  14. raynewman
    raynewman Active Member
    Brisbane, Australia
    I am starting to appreciate how much hills (up or down change the numbers). On Thursday, I went Brisbane to Chincilla (300 KM) including going up the Toowoomba range which knocked the numbers down to having 78 KM left on arrival from a full charge.
    On the way back on Friday, after coming down the Toowoomba range, my 50KM energy use average dropped well below 100 W/KM.
    Going from Brisbane to Toowoomba is an elevation increase of over 2000 feet.
  15. One Gear
    One Gear Member
    Australia
    I had no range anxiety at all. I feel pretty confident that the car can make that leg in one charge in just about anything. The weather was pretty awful for that return journey. Elevation, weight, wind and the very heavy rain, combined with a high speed limit of 110kph, all would have had a significant impact on range (just as they would have for an ICE car).
  16. lonewolf313
    lonewolf313 Member
    Sydney Australia
    Hi Ray
    Not owning a Tesla myself, when you range charged from Brisbane to drive over the Toowoomba Range, what was the car showing as estimated distance with 100% battery at the start of your journey
    I've seen YouTube videos of Bjorn Nyland (from Norway) with a P85 and on 100% charge, he only has an estimated range of 400km (on a car which has already travelled more than 100,000 km)
    For you to drive 300km and still have 78km left over an elevation of 2000ft is still quite amazing
  17. raynewman
    Brisbane, Australia
    Range charge on my machine is 502 KM.
  18. lonewolf313
    lonewolf313 Member
    Sydney Australia
    Interesting, your car actually shows 502km when 100% charged. I thought that was a figure created by Tesla (as a factory benchmark) but not really achievable in the real world. Better for them to say the car can reach 502km on 100% rather than 485km
    So theoretically, on your return journey (downhill from Toowoomba to Brisbane), you could get around 580km on a full charge to zero km.
    Given that you lost approx 120km on your uphill run and reclaiming 80% of that loss on the downhill run back to Brisbane
  19. raynewman
    Brisbane, Australia
    I have seen it show 504 KM but 502 is more usual. Chincilla itself is at about 1000 feet elevation so the calculation is a little more complex.
    Also powering past road trains on the way out probably made a difference :)
    Having said all that, after a previous long and slow downhill run, the expected range after a full charge was over 700KM.
  20. TesAus
    TesAus Member
    Sydney, Australia
    It depends whether you have the range estimate set to typical (based upon your actual historical usage - probably something around 200Wh per km) or the theoretical (based upon 181Wh per km). I use the typical as it is more accurate gauge for typical usage.
