Hello there, i've been following this forum for quite a while but never posted. However, I'm looking for a specific topic and haven't found it so I'm jumping in with my first post... Has anyone tried rustproofing their model S yet? I'm a reservation holder for now and looking at confirming soon. With the winters that we have in Qc (Canada) I was wondering if anyone had thought about rustproofing yet or if it's at all necessary. I'm planning to hold on to my MS for a while and therefore having to let it go because the Montreal salt rusted it would be very frustrating. if there is a post on that already my please let me know but if not, any reply would be appreciated. Thanks!
In my experience with aluminium is that it wont corrode, everything on my boat is stainless steel or aluminium and it is drenched in salt water regularly. Aluminium will oxide on the surface to produce a protective layer that stops further corrosion. Also my dads A8 is clear of any corrosion while the steel cars here are usually perforated by rust, any bolt that's galvanized steel will get corroded heavily.
I drove the Land-Rover Series III for twenty years in Canada (not in Quebec though), but everywhere west of Toronto and no corrosion of the aluminium. I don't know if there was a special aluminium alloy that doesn't corrode, or if the aluminium needs to be next to certain other metals, or if there are sacrificial anodes that corroded without my knowledge.
Just found the followig thread thanks to your answers : Road Salt effects on the Model S Just doesn't have the word rustproofing in it which might be why I never found it before. Thanks a lot for the quick replies!
DTB, you contacted me via PM but I tried to reply and got the message that your inbox is full and that you need to clear out some messages. Do that and I will answer you. this is the message i received when I tried to reply: DTB has exceeded their stored private messages quota and cannot accept further messages until they clear some space. Znino
Will do! I also tried to reply here but apparently an admin has to verify my messages first... Hopefully this one will go through.
I took your post out of moderation a while ago. The server's threshold for putting posts into moderation is much lower until you've been a member for a bit. It twigs on certain keywords, links, etc.
Saw that. Seems all fixed now! Many thanks to you Doug_G and to everyone who was kind enough to answer my questions... You know who you are :wink:!
Here's something that I just encountered - see Model S Technical / Mechanical Issues - Page 180 My car probably just has a defective part, but this one part is so badly corroded that it has cracked and bent. If your car has experienced a Canadian winter it might be worthwhile to give it a quick check. Just pop off the plastic covers on either side of the frunk.
Thanks for the heads up Doug! I saw your post in the other thread but didn't realize where those pieces were... Anyways I popped the covers off and mine look totally fine.
I'm checking mine this weekend. I had a look under the frunk over the lunch hour and assume the plastic pieces are the ones down each side and not the single piece along the windshield edge (that is the one I had off before to check my fuses).
Maybe you should mercury-proof it? The Amazing Rusting Aluminum (WWII commandos may have sabotaged Nazi planes with this trick)
Had a look at mine today. Drivers side is definitely corroded albeit not as bad as Doug_G. No cracking or anything. Car is going in for a service in a week. Will ask about it then. Picked my car up the same day as Doug (Dec) but driven in a slightly more benign GTA winter than Ottawa.
Yeah, GTA winters are a lot wimpier. I doubt there's anywhere in the world that is worse for salt corrosion than Ottawa or Montreal.
They may be wimpier, but there not shy with the salt and liquid salt brine around these parts. Very little sand is used I believe because the temperatures we get in the GTA will still work with salt.
