Model S - Silver Slip Stream 19 inch Wheels with Winter Tires
I have a 2016 pre-Facelift Model S. If the wheels will fit and my tires can be used I am interested. I want to use my existing Michelin tires mounted on the stock non-slipstream wheels.
The wheels will work on your car, @waichner
The older cars have an older TPMS that only give high or low pressure warning. Newer cars with newer TPMS give individual tire pressure on the screen. Hence the VIN number range on Tesla’s website.
If you had the older tire with a newer car, you can use the tire, just need to get the TPMS swapped. In this case it looks like the tires should work on your car without changing TPMS.
Reactions: Deans
