Model S Slid Away...
Discussion in 'Model S' started by Dgogs, Feb 19, 2021.
  1. Dgogs
    Dgogs Member
    Massachusetts
    Hello, I also posted on Tesla Form, however between their form and TMC I have been able to obtain so much information by reading the posts. I figured it wouldn't hurt to reach out on here as well.
    What brings me here today is a fairly unusual even that happened to me today with my Model S. After running errands today I returned home, parked my car and plugged it in. It was snowing today but living in New England, I did not think much about it.
    So I go into my home and am inside in my kitchen and I hear the alarm on my car and then get an alert that "Sentry mode has triggered the alarm state". Since I didn't hear the driveway alarm and was home alone I found this odd. Well... I go outside to find my car in the middle "island" of my driveway. Thankfully sentry mode recorded most of the event, however there is a second or two lapse between clips. Posted link to the video below.
    So here's my main question for today. From my understanding every time we put any Tesla in "Park" the emergency brake is auto applied... is this correct? My insurance company is trying to blame this on that or that there was a defect on my car, but there has never been an issue with it nor have I had ANY complaints at all during my Tesla ownership. Even the service center experience (Warwick, RI) has been very pleasant, which I know isn't always the case for everyone on here.
    There is quite a bit of damage caused by this event. The Tesla Wall Charger plug prongs are ripped out (but the charger base is still attached to my house), the front of my cars over bumper is cracked, the charge port is shattered and the charge port door went flying, and the entire driver rear side rear is dented in multiple spots and where it is not dented it is very deeply scratched, and the left taillight is ruined and ready to fall out.
    Thank you for any input!
    • Informative x 4
  2. domodan
    domodan Member
    UT, United States
    What did Tesla say? They should be able to look at logs from the car and see what happened. It’s like it came out of park all on its own?
    Crazy!
  3. Dgogs
    Dgogs Member
    Massachusetts
    I called my service center and they said to have it towed there tomorrow so I am hoping I will know more then. I took the hard drive out of the care so I could prove to them that I wasn't inside or trying to drive. Not that the car even would let you if it is plugged in. o_O
  4. Dgogs
    Dgogs Member
    Massachusetts
    * car. I took the hard drive out because I didn't want the video to get overwritten.
  5. hpartsch
    hpartsch Member
    wa
    Wow...
  6. ucmndd
    ucmndd Well-Known Member
    More than likely, this is simply the result of parking a car on a sloped slick surface and inertia/gravity doing its thing. There have been a few similar reports over the years.
    With EVs the only mechanical brakes are provided by the parking brake - there’s no equivalent to putting a transmission in “park”. Practically speaking this means only two wheels are “locked” by the parking brake in the rear. The front wheels have no resistance or mechanical lock.
    I’d bet my life the rear wheels were indeed locked in place by the parking brake, but that’s not going to do much for a 5,000 pound car parked on a slope on a sheet of ice. For that matter I doubt having all four wheels locked in place would have made much of a difference either.
    • Like x 13
    • Informative x 2
  7. teko
    teko Member
    Seattle
    Looking at the video it does not look like wheels are spinning. So car was sliding down the hill on ice. Should have used tire blocks. Not that I would remember to do it.
  8. jjrandorin
    jjrandorin Moderator, Model 3, Tesla Energy Forums
    Riverside Co. CA
    The video looks to me like it does to you. It looks like a car, parked on a slope (where the slope is basically frozen / ice), and it slides down because of gravity.
    In my opinion, the title of this thread is misleading. The car doesnt appear to "roll away" it appears to "slide away". Thats a big difference. "Rolled away" implies the wheels were turning or there was some type of propulsion or something.
    In fact, if I was this OP, I would likely take this video down / remove it from the thread and anywhere else online, since I dont think it shows what they imply it shows.
    • Like x 8
    • Disagree x 1
  9. Dgogs
    Dgogs Member
    Massachusetts
    Thank you for the info and clarification. I am sure that is it, what is crazy to me is I have parked in the same spot in much worse winter weather and it never moved AND this happened after about 30-45 minutes after being home. My next question would be, has anyone had any experience with Tesla doing body repairs?
  10. sorka
    sorka Well-Known Member
    Merced, CA
    Looks like passenger rear wheel was locked and that the car slid down the hill based on the second video.
  11. jjanov79
    jjanov79 Member
    Austin, TX
    From the video it definitely looks like the car was sliding as opposed to rolling since the tire tracks are solid black (no tread marks). They should be able to pull logs to verify this. If that’s the case the car didn’t fail… it was in park with the wheels locked. Without more info on changing weather/temp from the time it was parked until the incident it’s hard to speculate if that was a factor.
  12. domodan
    domodan Member
    UT, United States
    Yeah, that’s just an accident. I’d argue weather related and no fault of yours. Should be a comprehensive claim, no different than if a tree fell on it.
    • Like x 14
    • Disagree x 1
  13. futureprimitiv
    Los Angeles
    • Informative x 2
  14. David.85D
    David.85D Active Member
    #14 David.85D, Feb 19, 2021
    I’ve had my Model S slide on my driveway. I opened the door and the shock of me flopping into the seat got it started. I didn’t realize what was happening at the moment. Luckily it wasn’t plugged in and my driveway levels off. Now I salt / scrape / shovel / etc before parking…
    The only question I have is whether the “extra” parking brake (long hold to activate) is better under these conditions - is it activating all 4 wheel calipers or just the 2 parking brake calipers?
    Oh, and one more plug for back end in parking. If the car was parked for the whole storm, there will be a snow free area under the car. If the rear end of the car is uphill, it will slide and stop on the clear area. If the rear end is downhill, once it starts sliding, the wheels with the parking brakes are on ice and … game over.
    • Helpful x 2
  15. Dgogs
    Dgogs Member
    Massachusetts
    Thank you for your input. I by no means was trying to be misleading and do apologize if it seems that way. I simply wanted input from other Model S owners. Since I do see that you are a moderator, if you can change the title of this post to slide or similar please feel free. Or if you have instructions as to how to do so I would appreciate it. The video is not publicly listed one YouTube, it is available by having the link only (which I did ONLY post on here).
  16. jjrandorin
    Riverside Co. CA
    #16 jjrandorin, Feb 19, 2021
    I dont have mod rights in this section (the "mod powers" are split up between people who spend their time in specific sections). I cant change the title here. Just to be clear though, I wasnt posting my comments as a moderator, but as a regular member. it was just my opinion personally.
    I didnt feel strongly enough about it to report it to a mod for this section. If you want to get it changed, you can report your first post and ask a mod for this section to change it, but I wanted to be clear that I was not saying that "as a mod" but it was just my opinion as a regular user.
    The reason i was saying that about your video, is because it sounded like you were in a "dispute" with your insurance company. It appears to me that, like someone else said, this isnt much different than a tree falling on your car in your driveway. I dont think you did anything wrong here, this is just bad luck of the car sliding away on an icy sloped surface.
  17. Art_Vandelay
    Art_Vandelay Attractive Membrane
    Elon’s left eyebrow
    #17 Art_Vandelay, Feb 19, 2021
    I've seen at least 2 other similar events: One on Twitter in Belgium and one on Reddit in the US.
    Quick question. What kind of tires do you have on your Model S?
    Anyway, that really sucks. Hope your insurance company doesn't make it even harder than it already is for you.
  18. BCTS
    BCTS Member
    Melbourne
    We don't have these issues in Australia when it comes to that level of snow/cold.
    But I guess as more and more low resistance/low drag tyres are designed for BEV's... This could occur.
  19. BigTonyTones
    BigTonyTones Member
    Los Angeles
    That is crazy thank you for sharing
  20. BigNick
    BigNick Disaffected Member
    Pennsylvania, USA
    This happened to me decades ago in a much lighter car. It started sliding slowly and I was able to grab onto it and stop it. This was after I had put the car into Park, set the handbrake, exited and walked about 20 feet or so.
    Tires are the main difference. Worn-out tires or excessively hard non-winter tires will slide more easily than grippier cold-weather-optimized tires (or studded tires.)
    If I had to have a sloped driveway I would rather have gravel than paved.
