…Will they work on a model X (2020)
Just a word of caution. S and X rims may have the same bolt pattern but they are different in other ways.
Those S rims are likely not rated for the weight of the X. Probably no tire shop would notice but if they knew likely they would not work on them. Almost certainly Tesla will know this and won’t work on them.
You may also have speedometer problems as the outside diameter of those tires is smaller. When you replace the tires you can order higher profile replacements to get back to original diameter.
Not sure about any alignment issues.
Not sure about width issues, but S rims are likely thinner, so it shouldn’t rub.
Not sure about the Smaller S rims clearing the X calipers.
Not sure about offset differences.
Also, as if I haven’t made the discussion complex enough already, I am pretty sure those rims are not slipstreams.
