I have a 2016 Modal S and I can't figure out what sometimes when you let up on the accelerator the car slows down fast and then other times not as much. This may be a dumb question so go easy LOL
It doesn't need to be "particularly cold" to see regen reduction. You'll start noticing regen reduced as ambient temps get into the upper 50s if it sits for any amount of time for the battery to cold soak. On my MD90D, if I let it sit for a day in my garage, which is running about 45 deg F, I still only see 25-30 kW of regen capability, so about half what I'd have when the battery is fully warm.If the battery is particularly cold it can't accept energy very quickly and regen will be reduced.
I never fill over 80%. It does it inconsistently during a single drive. So I am driving and let up and it seems to not slow down at all. After I come to a stop the next time it will start to automatically slow down. I thought maybe if I set the "H" hold at a light the next time I take off it doesn't slow down and if I use the brake then it works but that is not the case. It feels like there is no consistency on when it works. I will keep monitoring it. I thought maybe I was doing something wrong.Battery state of charge (%) and battery temperature have a lot to do with it. If the battery is nearly full it can't do regen to slow down because there's no where for the energy to go. If the battery is particularly cold it can't accept energy very quickly and regen will be reduced.
Do you noticed either or both of these circumstances when there is less resistance when you lift off the accelerator? Any other circumstances you might find are often present?
It shouldn't be that inconsistent. On your instrument cluster, do you have the energy graph as one of your options? It looks like a 3/4 circle - when you accelerate, you'll see the gauge fill with orange from the right toward the top and top left. When you let off and are regenerating, you'll see it fill with green to the bottom. That's your battery in/out gauge. If the car is limiting your regen for whatever reason (cold, battery full, some other issue), you'll see dashed yellow lines around that bottom portion, indicating you don't have the full amount of regen available.I never fill over 80%. It does it inconsistently during a single drive. So I am driving and let up and it seems to not slow down at all. After I come to a stop the next time it will start to automatically slow down. I thought maybe if I set the "H" hold at a light the next time I take off it doesn't slow down and if I use the brake then it works but that is not the case. It feels like there is no consistency on when it works. I will keep monitoring it. I thought maybe I was doing something wrong.
It's possible part of what you feel as inconsistency is the fact that a fixed regen braking power level "feels" different depending upon your speed and the terrain.It does it inconsistently during a single drive.
Do you drive or power off/on in between changing the settings? Or just click Low then High again in one motion?On my 15 P85D, I experience the same, and swear that turning regen to low, then normal gets it going again.
Low then high, usually stopped at a light or stop sign.Do you drive or power off/on in between changing the settings? Or just click Low then High again in one motion?
