My 2015 Model S had my door speaker burned out for ages and the sound is terrible. Finally, had found the place to buy a 3d printing speaker mount for Model. After reading and watching so many speaker reviews, I decide to go with Alpine S Series. So before taking out the door panel I prepare the following items
4 x 3D Print Speaker Mount
Alpine Speakers
Parallel Wire Connector
Sound insulation foam
So first I need to Prep the speakers before installation. Just connect the wire, I like them soldered. Add some insulation foam in between the speaker and the mount. Do the same for all 4 speakers.
I watched this videos from Andre Rink to learn how to get the door panel out, all 4 doors are the same.
Finally, I just cut the speaker wire from the car speaker and use the connector I bought from amazon. The door speaker is actually quite easy to replace.
For the A pillar is also not to hard, just un-screw one screw in the air bag plastic cover. Pull the A pillar out and you will find the tweeter. For the tweeter I just use the insulation foam to wrap around the after market tweeter, and push the tweeter into the A pillar tweeter socket.
After all the installation I would say its all worth, as I know many Model S owner also got their door speaker fail. After replacing the speaker it’s like a completely different car. The base finally comes back and I can turn up the volume and still getting very good sound quality.
3D Print Speaker Mount, with this I no need to use recover speaker from the door
Foam tap around
I like to solder the wire not to use the stock connector
Screw on the speaker to the mount
Just search on amazon for Parallel Wire Connector, can be found very easy
Very easy to use, quick connect no need solder
Since the tweeter is different size from the stock tweeter, so I just wrap some insulation foam around to increase the size. also the foam can also be a buffer
Remove the speaker can put the new speaker on. I just cut the stock connector and use the quick connector I have
Dont take the whole a-pillar out, will be hard to put back in. Just take it half way out is fine
Cannot post more pictures, so I will post it in the thread
Alpine Speakers
Foam tap around
