smorgasbord
OK, just tried some math:
I've read here that the 40kWh pack uses 2.2AH batteries. The 85kWh pack uses 3.1AH batteries.
That works out to about 5050 batteries in the 40kWh pack and 7616 batteries in the 85kWh pack. Both very approximate, of course. From the Panasonic spec sheet, the 2.2AH batteries weight 44grams each and the 3.1AH batteries weigh 45.5 grams each.
Thus the difference between the two is 765lbs-490lbs, or 275lbs difference.
Given that the Roadster battery, with 6831 cells weighs 990lbs, battery weight is about 2/3 of the pack weight. The question is whether the high capacity pack has more "packaging" which also increases weight. So, one guess is that the 85kWh pack weighs about 360lbs more than the 40kWh pack. Pretty close to WhiteKnight's guess.
