Model S Tech Talk
Discussion in 'Model S: User Interface' started by Kipernicus, Feb 8, 2012.
  1. Kipernicus
    Kipernicus Model S Res#P1440
    Belmont, CA
    There's an event this weekend at the Menlo Park store:
    Join us at Tesla Menlo Park for a Model S Tech Talk February 11th, 3pm.
    Model S Beta Prototype Display Hours
    February 11th - 12th
    Saturday: 10am-6pm
    Sunday: 12pm-5pm
    Nicolas Verzeni, Manager, Powertrain Research & Development will host a technical discussion about our ground breaking Model S platform and the advantage of building an electric vehicle from the ground up.
  2. gg_got_a_tesla
    gg_got_a_tesla Model S: VIN 65513, Model 3: VIN 1913
    Redwood Shores, CA
    I'll be there with my wife (who's shown interest for the first time in checking out the beta!) and son.
    Does anyone have any questions that Nicolas can possibly answer? No, not about the leather seats and such :smile:
  3. vfx
    vfx Well-Known Member
    CA CA
    That's the way. Wear 'em down!
  4. Mycroft
    Mycroft Life happens
    On my boat
    Yes, ask him if he can speak to the reasons for the 40kWh pack being ineligible for the supercharging system. Some of us have stated our suspicions, but that's all they are.
  5. Kipernicus
    Belmont, CA
    I plan to ask about variable regen and coasting and "one pedal driving".
  6. tdelta1000
    tdelta1000 Active Member
    South Florida
    That's a great question.
  7. Trnsl8r
    Trnsl8r S85 2012-2018, X90 since 2016, 3 since 2018
    San Jose, CA
    Not a very techy question, but maybe ask about tow points? (No not for Model S to tow something, but in case Model S needs to be towed.)
    Models S...Tow Points
  8. GSP
    GSP Member
    I would appriciate asking the following. I had to take my Volt through about 18" of water on the interstate. I had no other choice. I knew it went through GM's standard fording tests OK, and GM has posted a video with water comming up over two feet, so I had confidence. I did it with no issues. I would like to know if the Model S will be capable if ever needed.
    What are the Model S's fording capabilities? Can you submerge the powertrain without damage?
    Thanks,
    GSP
  9. AnOutsider
    AnOutsider S532 # XS27
    That's actually a great question -- one that may even come up for the Model X as well
  10. doug
    doug Administrator / Head Moderator
    SF Bay Area
    I might not be able to make it, but here are a few questions:
    • What is the resolution of the 17" touchscreen? Is it LED backlit with dynamic "local dimming"?
      Do the screens have an ambient light sensor to automatically adjust brightness.
    • How well are critical functions isolated from infotainment features. (Back at the 2009 LA premiere, a frozen/locked-up touchscreen also meant a frozen speedometer during a test ride.)
    • Has Tesla been following or are they aware of the many bugs the Fisker Karma is currently suffering? This is the risk of putting so many things under software control. What is Tesla doing to make sure they don't have similar bugs once Model S deliveries commence?
    • Have they made any progress deciding how they will package the 60 and the 40 kWh battery packs? Number of cells, etc..
    • Have they finalized how the Model S will handle DC charging? (Are they definitely using the SAE protocol with PLC?) Have they actually done DC fast charging with their new connector. (I believe the cars at the October event were charged using a different connector through the trunk.)
    • Has Tesla made any decision regarding 3-phase charging for European customers. (For example, in Switzerland they're limited to 16A single phase, which means 3.6kW charging for an 85kWh battery pack... likely over 24 hours for a full charge.)
  11. Norbert
    Norbert TSLA will win
    San Francisco, CA
    Partial answer: pretty sure the instrument panel and the center screen have separate systems.
    Questions: (Probably more than you can ask)
    When will the Supercharger announcement be made?
    Are there other differences between the battery packs than the capacity (and its effects on cycling) ?
    What is Powertrain R&D working on, in so far as it isn't secret?
    Will regen be adjustable?
    Will there be range mode, standard mode, etc, like on the Roadster?
    In how far is the Model S similar or different to the Roadster in regard to battery characteristics and are there resulting differences for the owner?
    Did testing with betas which are closer to production reveal that there might be small adjustments to the calculated 55mph ranges 160, 230, and 300?
    What are the ranges at 65 mph and 70 mph?
    Does the Performance version have the exact same battery pack as the non-performance 85 kWh version?
  12. eledille
    eledille TMS 85 owner :)
    Oslo, Norway
    #12 eledille, Feb 10, 2012
    • Will the HVAC be able to heat the car to a comfortable temperature when it's -20° C (-5° F) outside?
    • In case they answer "yes" to doug's question about 3~ support, follow up with "That's not just plug compatibility with only one phase connected, right? All three phases will be utilized?" (*)
    • Whenever Tesla decides to support three phase, will 230 V three phase be supported in addition to 400 V? (**)
    • Tesla will eventually have to support three phase charging at 44 kW if you want to sell any cars in Europe. Even the little Zoe supports this. Will Tesla follow Renault's example and integrate the three phase charger with the motor drive, to be able to reuse the regeneration circuitry to charge from the grid?
    (*) Both Tesla's Danish and Norwegian representatives have answered "yes, we will support three phase", when all they had to back up their claim was three phase to Tesla adapters that only connect one of the phases.
    (**) This would be very much appreciated in Norway.
  13. eledille
    Oslo, Norway
    #13 eledille, Feb 10, 2012
    If you add "in practice" to that sentence, you can replace "Switzerland" with "Norway, Sweden, Denmark, Finland, Germany, Switzerland, the Netherlands and Austria". Italy and France are also very much affected, even though some single family houses in those countries may have single phase incomers, many don't. Even those that have single phase incomers (mostly apartment dwellers) will usually not use it to charge their cars, as they either park in the street or in a private car park in the basement.
  14. dsm363
    dsm363 Roadster + Sig Model S
    Nevada
    They has a cool web page last night where you selected battery pack size, speed, tire size, wheel size, windows up or down and use of AC and it told you your range. They said it wasn't up on the website but might be in the stores in the touch screens soon.
  15. ElSupreme
    ElSupreme Model S 03182
    Atlanta, GA
    Which was worse? Windows down or AC, at say 55mph?
  16. dsm363
    Nevada
    Using AC dropped 40 miles off of 300 mile pack while windows down was maybe 10? Can't remember the exact numbers.
  17. ElSupreme
    Atlanta, GA
    Good to know. That is a big win for me.
  18. tdelta1000
    South Florida
    #18 tdelta1000, Feb 10, 2012
    Here's a good question, how much power would be used to cool the S when it's not in use? And how much of the range will be affected by the cabin cooling system?
  19. NigelM
    NigelM Recovering Member
    Northern Virginia
    My Florida experience: it depends on the ambient temperature. I notice that the Roadster fans run a lot less in winter than summer. Regardless, I always try to park in the shade...
  20. eledille
    Oslo, Norway
    Another one: Will the battery cells be balanced during every charge, or only when charging fully, like in the Roadster? This is interesting because with such a large battery as 60 or 85 kWh, a requirement to charge fully every so often to keep the cells balanced would lead to the battery spending a lot of time near full SOC, which would probably impact battery lifetime.
