Model S Technical / Mechanical Issues
Discussion in 'Model S' started by DrComputer, Sep 27, 2012.
  1. NathanLew
    NathanLew New Member
    Wales
    I don't have a multimeter but I have ordered one, should come in a few days.
    In the mean time I did hook up the battery to a battery maintainer and let that charge overnight and now when I get in the car the screen on the dash comes on but not the large screen in the center, it says to book it in for a service and is showing charging complete at 0 miles.
    When I try to plug the charger in it wont accept it, the only way I can get it in is by holding the release down in the boot while pushing the charger in and when it does click and lock in the light next to the port is red instead of green, it does eventually switch to green but does seem to charge the car at all. And I can't see how the car would have discharged all that energy over just a few days, it was fully charge and had 160 miles on it, so think it may just be the dash showing wrong. I have booked a service but that's not gonna be until 20th of July.
  2. aerodyne
    aerodyne Active Member
    Los Angeles
    There is more you can do, but it sounds like a 12v problem to me. Charge until you see 14.0 to 14.2 V and try to start the car again.
  3. amiral_sub
    amiral_sub Member
    Bordeaux, France
    The sc confirmed that my car had a wire cut. The repaired it for 110 €. Now I see the both air intake open at the same time!
    • Informative x 2
  4. Jeff and lori
    Jeff and lori Member
    Another OUTSTANDING Portland SC experience. Since the SC is 6 hours away, I save up my warranty issues for several months before scheduling, so I’ll usually have numerous items to address.
    This time was peeling chrome on both side mirrors, floor mat anchor velcro torn loose, bubbles on center MCU, leaking sun roof with subsequent water stains down both A pillars, & loose lug nut caps.
    Dropped the car off on a Wed and was given a clean MS to drive home. By the following morning got a notice that all was done. Came back the following Monday (no hassles at keeping the loaner for several days). When picking up the car, noted that the A pillars had been cleaned but could still see slight ghost image of the stains and requested the interior trim be replaced. They said they couldn’t see them but immediately agreed to replace. They scheduled a Mobile Tech for that,
    Tech showed up at house a week later and replaced in less than hour.
    We have always had Great service at Portland SC and wanted to recognize this.
    • Informative x 2
  5. aerodyne
    Los Angeles
    Would you recommend even if it was 12hrs? Not having that good an experience in LA...
  6. Rk2008
    Rk2008 Member
    Charotte
    Hi, I have a 2016 MS and received two errors today.
    bms_u008 : Acceleration and top speed reduced. Performance may be restored on next drive
    bms_w172_sw_drive_iso : Vehicle may not restart. Service required.
    I turn the car off and restart and get the same errors. Worst part is the next service appointment is weeks out and need a car. Has anyone experienced these errors before? Any help is appreciated. Good thing is I have the extended warranty.
  7. pilotSteve
    pilotSteve Active Member
    Prescott Az
    sounds like your HV battery pack might be failing! Call service today and see what they say, happened like this to a friend and service remotely diagnosed failing battery, had the car flat bedded to service center, provided a loaner, and replaced the pack under warranty.
  8. aerodyne
    Los Angeles
    Or it might just be contactors inside the main pack. Much easier to fix. That is what happened to me last month.
  9. amiral_sub
    amiral_sub Member
    Bordeaux, France
    the last update fails to install. What can cause that?
  10. MichaelP90DL
    MichaelP90DL Active Member
    Lancaster, CA
    That happened to me when my 12-volt battery was failing. Replaced it, no more problem.
  11. amiral_sub
    amiral_sub Member
    Bordeaux, France
    but I don't have any low battery message
  12. craigger
    craigger Member
    San Diego
    Has anyone else had dash display reboots while driving on newer Model S's?
    I did our first long drive in our 2020 MSP on Monday (500+ miles). During the drive, the dash display rebooted 4-5 times while driving. First time freaked me out pretty good. After the trip, I did some research and it seems to happen to other people also but is this a pretty common thing? I was running navigation, XM radio, and running a better route planner on my web browser. When I got here I shut the power down on the car and also did the 2-scroll wheel MCU reboot to clear up any memory leaks. We'll see how the drive back on Saturday goes.
    Thanks for your input.
    -craigger.
  13. mmccord
    mmccord Member
    Pine Bush, NY
    Any hardware disconnected?
  14. amiral_sub
    amiral_sub Member
    Bordeaux, France
    no usb device connected
  15. EV-Fixme
    EV-Fixme Vendor
    Orange County, CA
    Can be the gateway card in the MCU. Your logs may have clues. I believe you have a upgraded eMMC?
  16. amiral_sub
    amiral_sub Member
    Bordeaux, France
    thank you for your reply. Mayb I was not enough clear, yes my emmc was upgrded. My mcu works perfectly but the last update fails to install. What is the gateway ?
  17. mmccord
    mmccord Member
    Pine Bush, NY
    Not what I was asking. I meant: is any of the car's hardware disconnected? Door handle unplugged, etc
  18. amiral_sub
    amiral_sub Member
    Bordeaux, France
    no, everything works
  19. EV-Fixme
    EV-Fixme Vendor
    Orange County, CA
    The gateway manages communications between the Ethernet and CAN networks.It has a SD memory card, which we have seen rare failures of. It is not the eMMC.
  20. amiral_sub
    amiral_sub Member
    Bordeaux, France
    tank you for the information
