I don't want it to seem like I'm hijacking this thread, but here's one more post on the coolant leakage issue to just to help drive home the point of how important it is to check for coolant leakage, especially if you are out of warranty. Here's an example of what can happen when the coolant leaks into the motor:
This particular large drive unit (or LDU) is seized up solid; meaning the rotor is stuck and can no longer spin. It was a replacement drive unit, and only had about 20-30k miles on it. As you can see, there's lots of crud built up in there, which is a result of the rotor and copper windings corroding, and then grinding on one another until it got to a point where the rotor could no longer turn anymore. We can try to press the rotor out, but this motor is most likely going to be a total loss, and the customer will need a new one (which is of course quite expensive).
Based on my experience, later LDUs (typically those that were new or replaced in 2016-2018) are the most prone to this seizing issue when coolant leaks in. Earlier drive units (2012-2015) don't usually seem to seize like this, but the coolant will still cause plenty of damage, and eventually migrates all the way through to the inverter and destroys it (also a very expensive repair). I've been rebuilding these things in increasing numbers over the past 3 years, and I can tell you that these days I have usually at least one or two torn apart every week out of just the Toyota Rav4 EV and Mercedes B250e alone (both of which were built under partnerships with Tesla, and use the same LDU as the Model S), and only about 10k were built between them. There are a lot more Model S's out there...
If caught in time, the motor can be taken apart to replace the bearings and the coolant seal. We can do all this at the shop where I work, and we always use an upgraded PTFE triple lip seal, and new hybrid-ceramic bearings that should last much longer than the originals.
All that being said, a
quick, simple check of the speed sensor could literally save you thousands of dollars, and a lot of headache. Also, like I said before in an earlier post, we can check your speed sensor for free at QC Charge in Vista California.
Note: Small drive units (front and rear) are not affected by this issue, only the large drive units are.
