Model S Technical / Mechanical Issues
Discussion in 'Model S' started by DrComputer, Sep 27, 2012.
  1. kevincwelch
    kevincwelch Active Member
    Chicagoland
    #21 kevincwelch, Sep 27, 2012
    Do you get the "floating" back-up cam video that won't swap? I noticed this in the Get Amped vehicles.
    This starting to remind me of the 15,000th auto fail in the movie Gung Ho.
  2. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    That could be due to battery balancing, which occurs when you leave the car fully charged. If that is the case, the rate will slow down.
  3. shokunin
    shokunin P85 & M3
    Irvine, CA
    Dadaleus was told that he should be careful with the "thin paint" which could be true. I didn't think the get amp tours paint was soft as even with the pictures from later events, the paint still looked good. It could apply to whole car or just the clear coat is thin.
  4. strider
    strider Active Member
    NE Oklahoma
    As Doug said, it's possible the battery is out of balance. I would keep driving and charging it each night and it'll shake out. Also it's good that you're letting it sit after charging. Balancing occurs after charging so it's good to let it sit for 30 mins or so afterwards (cable can remain plugged in).
  5. DrDave
    DrDave Member
    There is no way Tesla would let cars go out with thin clear - that is an instant warranty claim and the vehicle would have to be repainted. If Dada was told this by a rep, it's another case of a rep talking about something they were uninformed about. Until someone can tell me exactly which technology they are using (company and type), I am not buying the "soft" clear pguerra refers to.
  6. pete8314
    pete8314 Vendor
    DFW, ex UK
    +1 that idea, I think it'll be a lot clearer to have a dedicated sub-forum for bugs/issues/troubleshooting, ideally with a thread per problem...there seems to be a lot of commonality with the issues cropping up at the moment, or course over time, it won't stay that simple...
  7. mknox
    mknox Well-Known Member
    Toronto, ON
    From the Tesla Model S Warranty Guide:
    In addition to the above exclusions and limitations, this New Vehicle
    Limited Warranty does not cover any of the following:
    Any corrosion or paint defects including, but not limited to, the
    following:
    · Corrosion from defects in non-Tesla manufactured or supplied
    materials or workmanship causing perforation (holes) in body
    panels or the chassis from the inside out;
    · Surface or cosmetic corrosion causing perforation in body panels or
    the chassis from the outside in, such as stone chips or scratches;
    and
    · Corrosion and paint defects caused by, due to or resulting from
    accidents, paint matching, abuse, neglect, improper maintenance
    or operation of the vehicle, installation of an accessory, exposure to
    chemical substances, or damages resulting from an act of God or
    nature, fire, or improper storage;
  8. doug
    doug Administrator / Head Moderator
    SF Bay Area
    The easy thing to do was to add a wiki to this thread which I've done.
    If you have individual threads various issues you can also link to them in the wiki post.
  9. sublimaze1
    sublimaze1 8Dec2012 / Leeroy Jenkins
    Basin City, TX
    My oh My; there is some scary stuff in these last 28 or so posts. I certainly hope that many of them are because we (purchasers of this vehicle) are just a bit more hard-to-please than the average Joe. The paint issue bothers me. The pixels in the 17" bothers me more. The battery used to bother me the most, but if it is just a matter of "breaking it in", then I can hang in there.
    Waiting ... / P188
  10. ggr
    ggr Expert in Dunning-Kruger Effect!
    San Diego, CA
    Smith came down from Costa Mesa. It's an amazingly finicky job... I watched (and probably bothered him, but he's too nice to say so) during breaks between meetings. Took about 3 hours, with many adjustments to be made. As always I am extremely happy with Tesla service.
    At some point he rebooted the screens and the stray pointer droppings disappeared. I'm pretty sure they appeared while I was using the nav system, so I'll try that tonight, see if I can duplicate the problem.
  11. FlasherZ
    Small bugs are to be expected. Overwriting the wrong/video memory because you mishandled a pointer is a pretty common programming mistake. Let's hope all of their code review efforts have been focused on the drivetrain components. :)
  12. mknox
    Toronto, ON
    I hear you. Based on my mileage, I expect to blow through the warranty in about two years, and so far as I know there is no extended plan available. The warranty itself is pretty skinny (i.e. no paint or corrosion coverage at all - very unusual). I hear all of the very positive comments on how Tesla bends over backwards to make things right, and I'm sure that's true... but I do worry about expensive, uncovered repairs in just a few short years from purchase.
  13. chmod a+wrx
    chmod a+wrx Member
    Battery.....not sure......
    Screen.....this is probably a simple software or programming error......these things are typically easy to fix......
  14. Todd Burch
    Todd Burch Voltage makes me tingle.
    Smithfield, VA
    I wouldn't worry too much. We're very early in the rollout of a new product, so there are bound to be issues. They will be ironed out...and each new car off the line (and every new update) will fix issues. The great thing is that it looks like the drivetrain--the truly most important part of the car--seems to be rock-solid so far.
  15. RDoc
    RDoc S85D
    Boston North Shore
    I don't agree this is a minor software bug. I haven't seen that kind of software error since I stopped using assembly language. Something has to be very wrong with the OS and/or compiler to overlay memory addresses like that in a modern system. If they're using assembler, or some unprotected language like C, then there are likely going to be a lot of bugs.
    My suspicion is that the video hardware is broken.
  16. aviators99
    aviators99 Model S - R140
    Weston, Florida, United States
    I totally disagree, and I have 37 years of programming experience to back it up. Unfortunately, FlasherZ is correct, and this is a common programming mistake. It's something Microsoft is somewhat infamous for. If one of my programmers makes this mistake, they become someone else's programmer.
  17. ahimberg
    ahimberg Member
    Woodinville, WA
    Does someone have a picture of what this looks like? I have seen pixely lines that are hardware problems (had a vertical band of shimmery caused by overheating once), and patterns that are software, a picture might help the guessing :)
  18. smorgasbord
    smorgasbord Active Member
    SF Bay Area
    Got a picture to post?
  19. KenEE
    KenEE P1937 Reward Excellence!
    Texas
    That's just standard warranty speak. It's only covering Tesla against external circumstances beyond their control. Paint and corrosion *are* covered if the problem is or is caused by a manufacturers defect.
  20. pguerra
    pguerra Member
    Soft paint or not, the weak warranty on the paint would suggest to me that putting Opti-Coat 2.0 on the vehicle would not be a bad idea.
    I really hope this car exceeds my expectations ...and in a positive, not negative, way! Right now, things aren't looking too hot. Hopefully, "all the bugs will be ironed out" and "it's early in the production roll out" and "Tesla will take care of it" , etc.
    Only time will tell.
