Model S Technical / Mechanical Issues
Discussion in 'Model S' started by DrComputer, Sep 27, 2012.
  1. aviators99
    aviators99 Model S - R140
    Weston, Florida, United States
    Yes, I also have this problem.
  2. MikeK
    MikeK R#129, TSLA shareholder
    San Francisco Bay Area
    Have you found that it is losing fluid, or do you think it's just a spurious indicator?
    - - - Updated - - -
    A couple of things I could think to try:
    • Reboot the center screen by pressing and holding both the rollers on the steering wheel for about 15 seconds
    • Reboot the dashboard display by pressing and holding the top buttons on both sides of the steering wheel as above
    • Get in with the key, put the car into gear and then into park again, and then get out
    • Plug in the charging cable
  3. cinergi
    cinergi Active Member
    MA
    It appears to be spewing random errors at startup as of version 4... I've had wiper fluid low warnings a couple times... did nothing about it ... warning went away .. and now it hasn't happened for several days ...
  4. MikeK
    Ah. Interesting. I've only seen that warning, so I thought it might point to a real issue. I'll begin ignoring it now. ;-)
  5. contaygious
    contaygious Active Member
    Marina, San Francisco
    #385 contaygious, Dec 8, 2012
    Fixed it! The right door wasn't closed all the way. I knew this was ping to be a problem....
  6. PRJIM
    PRJIM Member
    Is there a way to turn off auto updates?
  7. JoshG
    JoshG Member
    YES! I've been getting this intermittently since picking up the car... maybe once a day i get the warning about low washer fluid. haven't bought or added any so don't know if it's real or not, but I'd be surprised if they don't check this at the factory at some point.
  8. bob_p
    bob_p Active Member
    My 2007 LS has XM NavTraffic - and warns you about upcoming traffic challenges, and can even offer to re-route you around the congestion.
    Does the Model S navigation have access to the traffic data? While it's visible on the Google Maps - that doesn't necessarily mean that the navigation software also sees and uses it for routing.
  9. aviators99
    Weird issue with the XM. When I'm listening to one channel and then I use the slider to get to another channel, a few seconds later the slider and display will show the channel number for the old channel. The audio is still for the new channel. I haven't experimented enough to track it down to when it happens, but it happened a few times today.
  10. stephenpace
    stephenpace VIN S00219
    Houston, TX
    It must. For example, it routed me a different way to Austin than normal due to traffic, and once the voice said something like "warning, accident reported ahead." Integration is subtle, though.
  11. ckessel
    ckessel Active Member
    #391 ckessel, Dec 9, 2012
    I know Tesla say the required door slam is by design, but when enough customers are having problems that tells me it's a bad design. Most other vendors seem to have normal doors.
  12. Robert.Boston
    Robert.Boston Model S VIN P01536
    Portland, Maine, USA
    Does it help to close the passenger door first? I wonder whether the last door closed, regardless of side, is simply meeting with air resistance.
  13. v12 to 12v
    v12 to 12v Active Member
    The Google Map does show traffic flow. I believe it picks up signals from Android phones that are on the road to determine the speed of traffic. There is traffic data for areas that I never imagined possible. (At the same time, I find it quite creepy and I doubt that I would buy an Android because of this and other data collection issues.)
    The navigation system does not offer up any route changes to compensate for congestion.
    - - - Updated - - -
    Maybe this is a regional feature. It didn't happen today when we came upon a back up due to an incident.
  14. Ben W
    Ben W P85 #61, Roadster #108
    Santa Barbara, CA
    Just ran into a strange situation with my Model S (Sig Special Performance #61). The car had been charging for a couple days on 110v, then left on the plug for about 12 hours "full", with about 245 miles showing in Standard mode. Then I took the car out to drive, and immediately got the dotted orange warning line on the speedometer indicating that the power was limited to about 200kW. (Normally it can go to 320+kW.) This doesn't make much sense; the batteries shouldn't have been too hot after sitting for two days in a Los Angeles parking garage, and the charge level wasn't too low. (Low charge can reduce max power.) Any idea what else could trigger this power limit? I took a screenshot to send to Tesla, and will ask them too.
  15. contaygious
    I had the power reduced issue today and I almost towed the car because I couldn't drive on the freeway, but they told me to hit power off and wait a minute and repeat 3 times and I did it and it fixed my issue so I could go fast again. They said there is a fix in date 3.5 I don't have yet so I'm just waiting for that and 4.0 to come still.
  16. Nickjhowe
    Nickjhowe Member
    Boca Raton, FL
    I've updated the Wiki Post at the top of this thread to start to summarize the issues and fixes people have reported. Any and all contributions accepted.
  17. EarlyAdopter
    EarlyAdopter Active Member
    Redmond, WA
    Do you have an iPhone or a Windows Phone 7/8? Apple and Microsoft collect the same traffic data on their phones.
    Apple says it's building 'crowd-sourced traffic' service for iPhone users
    Apple had a particularly bad bug a year ago where the phone's full location history was being kept in a file on the phone, never getting cleared, and it would end up backed up on your computer too, so anyone who got access to either could see every place you've ever been.
    Apple issues statement on iOS location controversy, says fix is coming
    In any case, the data sent to the service is anonomized and, at least for Android, the first and last few miles of each trip are dropped to ensure no data is kept about where you live or go. If it bothers you so much you can always opt out.
  18. aviators99
    Here's a picture of the XM bug. Apparently, it persists between trips, because I switched to 226 yesterday, and the picture is from today. The audio is coming from 226.
  19. PRJIM
    PRJIM Member
    Today my cluster showed regen, abs and traction control were all disabled. I tried to reset the cluster with the upper buttons but this had no effect. I ended up having to pull the fuses in the frunk. This happened twice. Very strange.
    Sidenote: The Model S is borderline undrivable with T/C disabled.
  20. Psullivan
    Psullivan Member
    Carlsbad, CA
    Hi, When you say the car is borderline undrivable with traction control disabled what do you mean exactly?
