napabill
I took care of a part of it by ordering the special option; the solid roof. Always closed. Works for me.:wink:I sure wish there were a way to ask the car to just "close up shop" -- windows, sunroof, etc. with one easy action.
Also - I have a crackling sound coming from the front speaker -- I cannot believe it is blown?
anyone else having these issue??
Anyone else noticing their car no longer locking when they walk away? The lights stay on for a long time (5+ minutes), and I thought it was just the lights but I was coming out of a store and someone I was with was leaving another store and walked toward the car. They pressed the handle and the door opened. I'd been inside for appx 8-10 minutes.
Walk away lock setting is on, and I turned it off and back on to be sure.
Are you sure all the doors were closed properly? I had this happen once when some loose cargo got caught in the door jam.Anyone else noticing their car no longer locking when they walk away? The lights stay on for a long time (5+ minutes), and I thought it was just the lights but I was coming out of a store and someone I was with was leaving another store and walked toward the car. They pressed the handle and the door opened. I'd been inside for appx 8-10 minutes.
Started to hear a rubbing sound through the steering wheel on slow speed turns of the wheel, such as parking lot maneuvers. Anyone else?
I hear more of a "straining" sound rather than a rubbing sound. Sorry for the poor description.Started to hear a rubbing sound through the steering wheel on slow speed turns of the wheel, such as parking lot maneuvers. Anyone else?
Does it change at all with the different steering settings?
I have a small issue that nobody else has mentioned I believe. I work pretty hard at keeping my car clean whenever I can. Whenever I wash my car, there is an area around the rear window that collects dirt and water when washing the car. Even if the car sits, the area around the rear window will expell water and dirt on the first drive following a wash, leaving dirt streaks down the rear of the car. I wish the rear window had a seal around the glass to prevent water from pooling in this area. Over time this area has to be an area for corrosion if it is not kept free from pooling water and dirt.
