FalconNinetyD
Tesla service dropped by my house Tuesday night to close out the punch list of items that I had since delivery. Here's my report:
3. Many of us were having difficulty closing the passenger door. I was one of them. This is NOT an alignment issue. It is indeed a pressure issue, and is due to the fact that the cabin is so well sealed. When you close the passenger door, the pressure builds up between the inner and outer seals, making the car difficult to close. (This also explains why it's still difficult with the driver's window open, which you think would alleviate the pressure. It's not due to pressure in the cabin, but BETWEEN the inner and outer door seals on the passenger side.
On the bottom of the passenger door, you'll find a round plug. Remove it and put it into the glove compartment. That should fix the issue, at least for now. BTW: This is an "unofficial" fix. I'm doing it because it fixed the problem. YMMV. (Note: I did not notice an increase in cabin noise after removing this plug).
Just went out to the garage and pulled one of the two plugs on the front passenger door, and that seems to help a lot. I'll still have Service look at it when I bring it in for due bill items, but his helps for now. Thanks!
