wormhole
Banned
I noticed the tires were Continentals. If it was a Performance + wouldn't they more than likey have been the staggered Michelin's?
Correct and still beat the S550
I disagree with this characterization.Model S. It's quick for a lap or two (esp on a 1 mile track) but the gets slower and slower as the motor gets hot and the power limiter kicks in.
It gets slower (as a step function down) when the limiter kicks in. From there it's steady, not "slower and slower".
Is there a link to the Top Gear episode that works?
It's available on demand or you can see it online here but you have to login with your cable provider credentials (VerizonFIOS, DirecTV, Optimum or Xfinity). Sorry, don't know if any of that applies to Canada.
No this doesn't work in Canada - thanks for the reply.It's available on demand or you can see it online here but you have to login with your cable provider credentials (VerizonFIOS, DirecTV, Optimum or Xfinity). Sorry, don't know if any of that applies to Canada.
I think what brian means is when tracking your car there are no "different levels of power limiting" that mnx is talking about. It's a sharp cut off to half power when a certain threshold is reached. The power does not gradually go down to half.You probably won't see it until you track your car.
See: http://www.teslamotorsclub.com/showthread.php/17581-Model-S-on-the-Track-A-Review
I was referring to track driving in my "stress" comment.You probably won't see it until you track your car.
Indeed. Crazy guy gets it.I think what brian means is when tracking your car there are no "different levels of power limiting" that mnx is talking about. It's a sharp cut off to half power when a certain threshold is reached. The power does not gradually go down to half.
There may be different levels when the battery is cold or too full (regen/power gradually returns as battery warms up or discharge).
That power limit came on the second lap(!). It would pull power back to about 160 kW, which was still quite usable. That would last about ten minutes before I started turning into a "rolling chicane". If I did a slow lap it would get faster again, for a while. A better approach was to pull into the pits. After a minute the power limit would disappear from the speedometer screen. I'd wait several more minutes then head out for another few laps.
I believe it will cut to 1/2 (~160kW) and then later reduce power even more. I believe that is what Doug_G is saying here: Model S on the Track - A Review
Again, this doesn't match my track experience with the limiter. I've only been through 5 days of such driving though, and maybe it varies by climate somewhat.I believe it will cut to 1/2 (~160kW) and then later reduce power even more.
Nah. That's nothin' to write home about.Here's a pic I took of the display during the stigs lap. Now that is a high average!
Turns out I had video of this one.
- Consumption: 10,667 Wh/mi (224 kW @ 21mph) [Autocross, 2013/06/23]
