Model S With 22" Wheels & Tires * World's First*
2. Here is the AEtwist 19" wheel that will fit the factory tire
The AEtwist 19 is a beautiful looking wheel. The one in the picture appears to be a two tone finish. Is it available in silver like the stock 21" turbines? Also, is it a direct replacement for the stock 19's or will it require any sort of adjustments? How does the weight compare?
Finally, can you share the cost? I looked at your web site but didn't see them.
Thank you!
just placed my order for the AE10's today. Ellie - is extremely professional and something that I appreciate! I elected to go a different route on the tires. I actually found what I believe to be an excellent tire at a great price. I'm going to try it out and if it works out well I'll post the results...
I will of course make sure to post pics.
Sorry for the delayed reply.
1. The stock 21" tires are 245/35/21 and the 22" that we use is 255/30/22. I tiny bit wider which not only helps with appearance but also puts more rubber on the ground which also helps.
Very sharp, beautiful work on these AEtwist 19s, great lines.
