Model S/X 100 peak charge power on Supercharger Gen3
Discussion in 'Model S: Battery & Charging' started by Zoomit, Jul 7, 2018.
  1. Zoomit
    Zoomit Active Member
    SoCal
    In late 2018 or early 2019, Tesla will start rolling out the Supercharger Generation 3 hardware. There's been a lot of speculation about what charging power that will provide to current and future Tesla vehicles. Over in this thread, I speculated that the Model 3LR will peak at 180kW on SC Gen3 based on the 525A spec listed in Tesla's EPA submission for that car.
    I was reviewing this excellent Supercharging data and realized we may be able to predict (aka speculate) the peak charging rate for the current Model S/X 100 vehicles by scaling up the S/X75 battery charging profiles. The S/X75 (BTX5) charging curve appears to be amperage limited.
    You can see the increasing power profile from 5% to 50%, up to a peak of 100kW. This likely means this S/X75 battery is charging at a constant amperage of around 286A [100kW divided by ~350V at 50%].
    The optimal S/X100 (BTX6) battery charging profile is flat from 10-60% at just under 120kW.
    This implies that it is power limited at 120kW, the max output of the current Supercharger Gen2. If we scaled up the 75kWh battery 286A peak to the 100kWh battery, it yields a peak charging amperage of of 386A [102.4/75.8 * 286A].
    That infers the S/X100 might be able to charge at 127kW near 5% [386A*325V] and may peak at 135kW near 50% [386A * 350V] using a Supercharger Generation 3. That's 1.32C [135/102.4], the same c-rate as currently demonstrated with the S/X75 battery, which has the same chemistry and cooling technology but a different pack density.
    • Informative x 5
  2. Zoomit
    SoCal
    I'll also mention that since the Model S/X90 and S/X75 batteries appear to be amperage limited on Supercharger Gen2, I expect those and earlier cars will see NO charge rate improvement on Supercharger Gen3.
  3. Zoomit
    SoCal
    Slight revision thanks to @George S. Bower. The S/X75 total battery should be 75.0 not 75.8 kWh. Scaling up the 75 battery to 100A yields a peak amperage of 390A [102.4/75.0*286A]. This means a peak of ~137kW near 50% [390A*350V] using a Gen3 SC.
  4. GWord
    GWord Member
    Houston, TX
    Bringing this thread back up from the dead since Gen 3 might be on the horizon at some point. If one looks at the C rate from the older 85 chemistry and apply it to the 100, you get an even more aggressive rate possible. 120/81.5 * 102.4 = ~150kW
