I have spent a lot of time looking at the economics of a Model S town car.
The main thing missing from this discussion is battery replacement.
A Lincoln town car will probably use fuel at about 22 cents per mile. ( 18 mpg - $4 per gallon )
You would likely want to replace the battery in the model s when it can no longer conveniently manage your 90th percentile day of driving. Let's say that is at 70% of capacity. If the battery is $35000 to replace after 100000 miles - that's 35 cents per mile and gasoline wins.
If the battery is $30000 to replace after 200000 miles, that's 15 cents per mile and electric wins.
In my dreams it's $25000 after 300000 miles, now you are around 8 cents per mile.
Which is closest to correct? We don't know.
I talked to a couple of small operators:
They buy Lincoln town cars <1 year used for $25k or so. They keep them for 3 years and 300,000 miles then they dispose of them for a couple thousand. Why? Because after 300k miles the transmissions start to go, and the engine soon follows.
( the operators I talked to see 100,000 miles per year and 300 mile days are typical )
That's about 7 or 8 cents per mile to own the Lincoln.
( there is probably another 2 or 3 cents per mile for oil changes, brake maintenance and tuneups )
The model S will be about $80k ( let's assume the battery is $35k of that and treat it separately ) so $45k. Hopefully you can keep it rolling twice as long as the Lincoln because it's drivetrain parts don't wear out. 600000 miles for $45k is about 7.5 cents per mile.
If that is true then we are back to the battery question.
Gasoline is the largest single ( non wage ) expense for the town car operator. If the batteries last long enough, the model s would give a huge advantage. Especially when gasoline is $5 and $6 per gallon soon...
Unfortunately we don't know how the battery holds up to 100000 miles per year nor do we have any idea what they will cost to replace.
