Model x 2018 22 rim tire pressure ?
Discussion in 'Model X' started by 16fragar, Aug 6, 2018.
  1. 16fragar
    16fragar Member
    Las Vegas
    I took delivery of a 2018 model x almost a month ago and my tire pressure shows low on the front 2 wheels they are at 40 psi and the back are fine they are at 41 any one knows what psi all should be ? Thanks
  2. P85_DA
    P85_DA Supporting Member
    My SC sets mine at 45 on 22s ...on my S also set at 45 on 21s... lower pressure reduces range
  3. 16fragar
    16fragar Member
    Las Vegas
    So i should take it to the sc right for they can do it or i can just go to like the tire shop and fill it up
  4. P85_DA
    You can do yourself I have a tire inflator that you can set what pressure and it will automatically inflate to that ...keep in mind your tire pressure will go up as you drive and it heats up
  5. 16fragar
    16fragar Member
    Las Vegas
    Okay thanks !
