Model X 2019 Raven Sound Deadening Doors Project
Discussion in 'Model X' started by ultraviolet75, Aug 11, 2020.
  1. DoctorVenkman
    DoctorVenkman Member
    Los Angeles
    Does anyone know if there are shops that are doing this sort of thing? I'm not very mechanically minded, but I'd be willing to pay ~$1000 for someone to do this to my car.
  2. Mandarin
    Mandarin Member
    WA
    There is nothing really complicated to do it yourself but you have to take your time. I did it too 2 months ago but went a bit different route in order to avoid weight gain and the main reason was to fix panels rattling.
    I have completed all doors’ panels including trunk lid panel, hands’ rest between front seats, and decoration plastic under the front seats.
    Now the interior is solid and quieter than before also made some improvements for sound deadening.
  3. DoctorVenkman
    Los Angeles
    I appreciate the words of encouragement, but I'm just not interested in taking apart my car, fiddling around with the doors for hours on end, and learning it all as I go. I'd rather just pay someone someone skilled to do it. The problem is I've never really seen this offered at any shop I've been to - would it be more up the alley of some custom/mod shop rather than a normal service shop?
  4. Mandarin
    Mandarin Member
    WA
    Any shop that makes sound systems will do.it for you for about $4k
  5. ShawnA
    ShawnA Supporting Member
    Edwardsburg, MI
    Hi DoctorVenkman,
    You might want to try Tesla mobile service to see if they would do something like this....
    They are really good at removing panels that we are afraid to break.
    Way back when, I had Tesla mobile install a very complicated sound reduction package
    in my Roadster - To look at it, it looked like the car exploded - there were so many parts
    everywhere... He finished and all was good.
    It might be worth an inquiry,
    Shawn
  6. JamXonit
    JamXonit New Member
    Bay Area, California
    Great write-up to the OP.
    I did the same thing with Dynamat on the front doors of my raven MX as well and understand your commentary on some of the hassle and acrobatics. Definitely experienced many of the same things. Was hoping to get a good reduction in road noise, but i think the reduction was marginal (maybe 1-2db reduction when i was baselining it with a sound meter app, so take that with a grain of salt on how well calibrated a app would even be), but the audio did sound a bit better for me with the stock system (still planning out a good aftermarket install, and the dynamat was all in prep eventually) and the more deadened sound when knocking the panels is apparent.
    I actually did dynamat on the front wheel wells in hopes to reduce further road noise in addition.
    All in all, not too hard a project if you know where the key points to take apart the panel (Definitely buy some extra clips that may break when doing this, which i think i had maybe 2 or 3 clips i ended up replacing) which i think the OP took good photos for all interested to key in on. But was a fun saturday afternoon project for a few hours to get real close and intimate with my car.
    to the OP (or any other followers on this thread) on this:
    • Have you gotten around to doing your falcon doors yet? It's been awhile since i dug around DIY on disassembling the falcon door panels to see any good write ups on it (which i was unsuccessful at). Would love to see a write-up on how you approach disassembling it if you got around to doing it.
    • Also, were you planning on doing sound deadening on the floor or the rear trunk panels? There's a number of write-ups i've seen with the MS and M3 on dynamat on the floors. Wasn't sure if that was worthwhile to further reducing road noise or if the battery itself is solid enough with the MX, although others have shown some big open cavities on the MS, so i suspect we may have that on the MX. Again, would like to know if there were anything to watch out for in trying to remove seats, etc. (i have a 7 seater) and how best to avoid causing scratches or damage trying to remove seats.
  7. mohanman
    mohanman Member
    Michigan
    Ultraviolet, can u share with us a bit more detail on the upper window seal that you put? It looks like u just put a small piece of seal into the existing seal to make the window touch better when you roll it up?
    Thanks
  8. Richbot
    Richbot Member
    STL
    Humor and information - excellent
  9. Rossy
    Rossy Member
    Hillsboro,Oregon
    I’m interested in the rear doors. Great write up. I’m an engineer so have to get a db meter and see what’s up.
    For me our dog is crying in the back of the MX, so I’m out to get (or make) a a special microphone that can measure sounds between 20khz and 67khz, which is in the dog hearing range we can’t hear. Most db equipment has filters to block sounds above that range. Not sure how far down that path I’m going to get...
  10. ljames28
    ljames28 Member
    UK
    There is the rear motor in the back which can be very whiney. There's a layer of foam/mass loaded vinyl/carpet. Without those layers it's very irritating to humans. Possibly the dog can hear frequencies we can't that aren't blocked by those materials.
  11. mohanman
    mohanman Member
    Michigan
    I highly highly recommend NOT to put those foam bags in the a pillar and the fenders. I recently took mine out because I wanted to see if they caused any problems as I started to get some creaking noises in that area. It was pain to get out, my hands have cuts and bruises all over. Secondly they were WET. They were soaked somehow, I think this could cause long term damage and even mess up the electronics, I do not recommend it!
  12. mohanman
    mohanman Member
    Michigan
    But as a side note ,I think I isolated some of my wind noise to this panel. when I looked up into the A pillar, there was quite a gap, and this was totally open, I could see light coming in from the outside, so i put some gorilla tape inside in that area. I think it helped, but who knows, lots of placebo effect too.
  13. Rossy
    Rossy Member
    Hillsboro,Oregon
    Yep, I found some good IOS apps which can sample above 96khz so I can examine the sound above human range. I can now see 20khz-50khz, had a $36 external lightning mic, but I bent it and it’s broken now :(. That mic was attenuated but I captured up to 50khz.
    Need to replace the mic and gather data. Then start looking at foam.
    [could also be that our boy is getting older and mechanical vibrations hurt his joints. He’s 8. We’re watching for that too. The Husky doesn’t like the car. Dauchsund doesn’t mind it at all.
    The last snowshoe trip the Husky was in visible distress. So we’re limiting his travel in the car until we figure this out. 9437E553-C973-4BCC-B59C-CD517BEE1E6F.jpeg CAFC2CF5-B80D-4969-AE99-8A25A341C380.png D2C581B3-0B0E-4714-AD25-8AF3E5298CEB.jpeg 13BC6041-2C49-460D-B144-B7945D7A06A8.jpeg
  14. sllvgl
    sllvgl Member
    San Francisco
    Thank you Rossy for your work, I’ll be looking for all your upcoming observations.
    Btw it’s 2020, your Husky could be a rich influencer dog doing car reviews on TikTok. Don’t miss the opportunity!
  15. ultraviolet75
    ultraviolet75 Member
    Sorry for the late reply. It has been a while since I've been on here.
    You are 100% correct. I just wedged the rubber tubing into the molding area where the window meets the top of the door frame.
  16. DelPhonic1
    DelPhonic1 Member
    Burbank
