Model x 2020 range
Discussion in 'Model X: Battery & Charging' started by gaz8000, Jan 31, 2021.
  1. gaz8000
    gaz8000 New Member
    Has anyone got a 2020 Model X long range that can tell me what the range should be?
    We received our MX in Aug 2020 and now at 100% it has 512km (318miles) I'm pretty sure when we bought it the range worked out to be 530km (329miles) but I can't be sure. 18km loss in such a short time seems a lot to me.
    We have 20inch wheels on atm. In summer 22inch.
    TIA
  2. T.R.T.e.s.l.a.
    LX
    The main range reduction should be felt in the first year, so maybe it's all good.
    Just keep an eye on it from time to time and unless the reduction increases or keeps a high rate in the next couple of years, i guess you're ok.
  3. AAARSINIC
    AAARSINIC Member
    Carlsbad, CA
    My long range late 2020 X has about 319 miles after a little over a year. It began with 328 miles. In my experience the first years degradation is the greatest and this is in line with what I expected based on my previous two Tesla’s.
  4. gaz8000
    gaz8000 New Member
    Yes but can anyone tell me what the range should be? I'
    ok, that's pretty identical to mine, so I'm probably worrying over nothing. It's my first Tesla so I have nothing to compare it to.
    Thanks for replying
  5. DandX1178
    DandX1178 New Member
    Fort Collins CO, - Baltimore MD
    I just got my 2020 Model X performance this week and when it's fully charged it says 300 mi. I am taking off on a cross country road trip tomorrow morning. Can anyone tell me if I should actually expect anywhere near that range on the highway, in chill mode? The Tesla planning site doesn't have me going that far in between superchargers at any point but I am wondering if it will be significantly less?
  6. DCGOO
    DCGOO Active Member
    Indianapolis, IN
    #6 DCGOO, Feb 11, 2021
    Yes, it will be significantly less. You might be able to get 300 miles if you never exceed 50 mph, but where's the fun in that. Does it have the 22 inch wheels with summer tires? You will be lucky to get 200, if that. First thing I would do is set the battery gauge to read % (Energy) as opposed to miles. Then watch the energy graph for accurate range estimates. I hope your alignment is spot on, often they are not from the factory.
    Chill mode makes no difference in energy consumption. It simply reduces maximum acceleration. 80 mph across Kansas consumes the same energy, regardless of how fast you got to 80.
  7. _jmk
    _jmk Member
    Finland
    I'd say you'll get 300 miles easily if it's relatively warm out, you never exceed 60mph and you don't stop until the battery is empty.
  8. DandX1178
    Thank you for the help and info! Currently the Tesla planner has one stretch, in Kansas no less of 205 miles between charges...
    Sounds like I need one of those portable generators strapped to the roof...leave it running with the cable plugged in the whole time I drive!
  9. DCGOO
    DCGOO Active Member
    Indianapolis, IN
    The on board planner tries to minimize the number of stops. Other trip planners like abetterrouteplanner.com, minimizes total travel time with more frequent stops. Given how cold it is this weekend, I would suggest not skipping over any Superchargers. I think along I-70 in Kansas, there is one every hundred miles or so.
  10. TespaceX
    TespaceX Member
    Hah, and who’s driving habit is just that?
  11. Xer2020
    Xer2020 New Member
    Indianapolis
    Have a 2020 Model X LR on 22s - new in June 2020. Max reported range on instrument panel display at that time was 352 miles... now (Feb 2021) max reported range is 340 or a little less depending on outside temps. Have taken multiple road trips of 330 miles or more (330 to 1200 miles) and can predictably attain a range of 200-212 miles on a single charge averaging speeds of 75mph. That's with outside temps at or around 32ºF to 80ºF +/-10ºF, no major head wind, and a fairly even distribution of uphill to downhill travel.
    That range dropped DRAMATICALLY
  12. Xer2020
    Xer2020 New Member
    Indianapolis
    on a recent road-trip out to Colorado by way of Missouri and Kansas during the insanely cold temps of -11ºF at the coldest and averaging 0ºF for most of the drive. During that time we averaged just over 110 miles between charging (note that most charges topped out at around 280 miles before we were prompted to continue the journey- that last 10-15% of charging takes a lot longer and is not worth waiting for, especially if you know your next charger is only 100 or so miles away. The other factors that likely contributed to the frequent charging was the fact that the drive is primarily uphill the entire way along I-70 heading West, and we had a pretty stiff headwind. But by far the ultra cold temps were the biggest contributing factor to the decreased range as a fair bit of energy is consumed keeping the battery warm and the cabin warm.
  13. msm859
    msm859 Member
    Just checked my 2020 X purchased December 2019 22k miles - moved lever showed 334 miles max.
  14. DCGOO
    DCGOO Active Member
    Indianapolis, IN
    #14 DCGOO, Feb 25, 2021
    That actually sounds pretty normal to me. You did not say what tires you have on the 22s, so I would assume you have the Pirelli summer performance tires that come with the wheels. They have a terrible impact on range, especially when it is cold. You need to remember the mileage shown in the fuel gauge, is a made up number to indicate how full the tank is. If you want to know the actual range estimated, use the energy graph. Personally, I suggest setting the fuel gauge to display energy (0 - 100%). It makes a whole lot more sense.
